frame grabbing
jameswilson
frame grabbing
Post by jameswilson »
Hi all im trying to grab a single frame and save as a jpeg every 30 seconds say. I cant use cron to do this im going to need some sort of script i suppose. Id like to cycle trhough a list of urls and save as jpeg ie site1-cam1.jpg, site2-cam1.jpg etc
Id like these jpegs to be overwritten say every 10 seconds to 5 minutes dependant upon settings. I can write a windows app to do this but not a linux one! so anyone any clues?
James Wilson
Flash_
Post by Flash_ »
First idea is to use cron, calling a simple wget command. I do this on a couple of axis cameras to get an image for a website
crontab entry, once a minute. Requires wget.
* * * * * wget http://10.0.0.108:1108/axis-cgi/jpg/ima ... on=320x240 -O /var/www/Stables.jpg &>/dev/null
That creates a 320x480 file "Stables.jpg". (As seen by the world as: http://www.mareandfoal.org/webcam )
Downside of that, no incrementing of filename. So maybe some way of furthering that line to test for a file and add to it, maybe bash or perl to inrement that line.
Anyway, hope it's of use as a starting point to you.
zoneminder
Site Admin
Post by zoneminder »
If you have a quick look at zm_monitor and zm_camera.cpp it might also help as that is pretty much what they do, just normally a bit faster. They capture Image objects which have a Write method and so are easy to write out.
Phil
