Page 1 of 1
libavcodec compile errors on Ubuntu
Posted: Tue Aug 01, 2006 3:50 pm
by DiegoLima
Hello again,
I have managed to compile and get zoneminder on an ubuntu machine some time ago, but without libavcodec support, so I don't get mpeg streaming. Whenever I try to compile after installing libavcodec-dev, I get these errors:
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header': undefined reference to `dc1394_create_handle'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header': undefined reference to `dc1394_get_camera_nodes'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header': undefined reference to `dc1394_dma_setup_capture'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header': undefined reference to `dc1394_destroy_handle'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header': undefined reference to `dc1394_start_iso_transmission'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header': undefined reference to `dc1394_dma_unlisten'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header': undefined reference to `dc1394_dma_release_camera'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_packet': undefined reference to `dc1394_dma_done_with_buffer'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_packet': undefined reference to `dc1394_dma_single_capture'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_close': undefined reference to `dc1394_stop_iso_transmission'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_close': undefined reference to `dc1394_dma_unlisten'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_close': undefined reference to `dc1394_dma_release_camera'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_close': undefined reference to `dc1394_destroy_handle'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_header': undefined reference to `ogg_stream_init'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_header': undefined reference to `ogg_stream_packetin'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_packet': undefined reference to `ogg_stream_packetin'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_packet': undefined reference to `ogg_stream_pageout'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_packet': undefined reference to `ogg_stream_flush'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_trailer': undefined reference to `ogg_stream_flush'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_trailer': undefined reference to `ogg_stream_clear'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_init': undefined reference to `dts_init'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_frame': undefined reference to `dts_frame'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_frame': undefined reference to `dts_blocks_num'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_frame': undefined reference to `dts_block'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_frame': undefined reference to `dts_samples'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_frame': undefined reference to `dts_syncinfo'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_info_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_encode_init_vbr'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_analysis_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_block_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_comment_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_comment_add_tag'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_analysis_headerout'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_comment_clear'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init': undefined reference to `vorbis_encode_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame': undefined reference to `vorbis_analysis_buffer'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame': undefined reference to `vorbis_analysis_wrote'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame': undefined reference to `vorbis_analysis_blockout'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame': undefined reference to `vorbis_analysis'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame': undefined reference to `vorbis_bitrate_addblock'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame': undefined reference to `vorbis_bitrate_flushpacket'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_close': undefined reference to `vorbis_analysis_wrote'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_close': undefined reference to `vorbis_block_clear'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_close': undefined reference to `vorbis_dsp_clear'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_close': undefined reference to `vorbis_info_clear'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_init': undefined reference to `vorbis_info_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_init': undefined reference to `vorbis_comment_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_init': undefined reference to `vorbis_synthesis_headerin'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_init': undefined reference to `vorbis_synthesis_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_init': undefined reference to `vorbis_block_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_frame': undefined reference to `vorbis_synthesis'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_frame': undefined reference to `vorbis_synthesis_pcmout'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_frame': undefined reference to `vorbis_synthesis_read'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_frame': undefined reference to `vorbis_synthesis_blockin'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_close': undefined reference to `vorbis_info_clear'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_close': undefined reference to `vorbis_comment_clear'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_frame': undefined reference to `theora_decode_packetin'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_frame': undefined reference to `theora_decode_YUVout'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_end': undefined reference to `theora_info_clear'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_end': undefined reference to `theora_comment_clear'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_init': undefined reference to `theora_info_init'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_init': undefined reference to `theora_decode_header'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_init': undefined reference to `theora_decode_init'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_init': undefined reference to `gsm_create'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_close': undefined reference to `gsm_destroy'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_encode_frame': undefined reference to `gsm_encode'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_decode_frame': undefined reference to `gsm_decode'
collect2: ld returned 1 exit status
make[2]: *** [zmc] Error 1
make[2]: Leaving directory `/home/inttegra/ZoneMinder-1.22.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/inttegra/ZoneMinder-1.22.2'
make: *** [all] Error 2
What should I do to fix this? Thanks!
Posted: Wed Aug 02, 2006 4:40 am
by cordel
The package you installed was obviously built with options from other packages (vorbis, dts, etc...). You would need to install these packages as well.
Regards,
Corey
