I use a proxy to access a remote camera server behind a firewall
I am streaming live video from the remote server using the following html code on my web page:
http://www.allenintech.com/cgi-bin/zms? ... =10&ttl=30
Of course the streaming stops after 30 seconds (due to ttl=30)
When I access the web page and list open files using,
/usr/sbin/lsof -i tcp:80,
Open connections from the client to the remote server are properly shown. See partial listing of lsof command:
TCP allenintech.com:http->wme.allenintech.com:59419 (ESTABLISHED)
TCP allenintech.com:60790->aitsurv.allenintech.com:http (ESTABLISHED)
TCP *:http (LISTEN)
TCP *:http (LISTEN)
I can view the live feed from the remote camera server. lsof -i tcp: 80 shows the connection from the client to the remote server. See partial listing below:
TCP allenintech.com:http->wme.allenintech.com:59023 (ESTABLISHED)
TCP allenintech.com:62345->aitsurv.allenintech.com:http (ESTABLISHED)
- (NOTE: ttl=0 or ttl is eliminated in the parameter list)
Can anyone point me to how to stream the video and have the remote server properly disconnect when the web page is close?
I am running zm 1.21.4
proxy server: RH 9.0, apache 2.0.40
remote server: Fedora 4, apache 2.0.54
Thanks in advance
amp
