zoneminder and libmp3lame error
il_boss
Post by il_boss »
Hi to all, it's the first time I write in this forum.
I'm try to use zoneminder with Fedora Core 5 on a PIII 700; 512 MB ram.
Following the instructuonI intalled ZM correctly but the problem is now.
When I try to start zm with "/etc/rc.d/init.d/zm start" the system retourn this error message:
Starting ZoneMinder: /usr/local/bin/zmfix: error while loading shared libraries: /usr/lib/libmp3lame.so.0: ELF file data encoding not little-endian
someone may help me? I miss something?
thank's
Boss
zoneminder
Site Admin
Post by zoneminder »
Do you get this error if you run zmc, zma or any of the other binaries?
What was your 'configure' line for ZM and which version of ffmpeg are you using?
Phil
