Is there anyway to get rid of the reflection of the leds reflecting off the glass inside a window?
Maybe some kind of film I can put up?
Any help would be appreciated.
ir led reflection on glass
- lazyleopard
To mis-quote Scotty: "Ye canna change the Laws of Physics, Capt'n"
Anti-reflection coating is an expensive business, even assuming it's possible. Anything that dulls the reflection is likely to make the lighing even less effective. Your best bet is to get the LEDs to other side of the glass, if possible. If not, see whether you can get the camera close enough to the glass that the LEDs don't reflect back into its lens. Other than that, or using a viewing angle that avoids the reflections, there's not much you can do.
Rick Hewett
I have tried the different viewing angle to not catch the leds, but at night it shows them pretty much anywhere. I will try getting it closer to the glass and see if that works. Thanks for the idea.lazyleopard wrote:To mis-quote Scotty: "Ye canna change the Laws of Physics, Capt'n"
Internal reflection is a problem with glass, you will need to get the lens sealed from the other parts of the glass with a rubber collar and get the cam right up to the glass
James Wilson
I had thought about making a cone from cardboard and using a large nylon washer to rest the cone against the glass. I guess this would be my best option. Will let ya'll know how it goes.jameswilson wrote:Internal reflection is a problem with glass, you will need to get the lens sealed from the other parts of the glass with a rubber collar and get the cam right up to the glass
thx
If you dont need the leds you could just cover them wioth tape
James Wilson
Internal reflection
A walk around is to have a IR-Cutt filter then you dont see the light from the LEDs.......and you don´t need to have any LEDs anyway:)
/NiGlim
/NiGlim
