I've just finished installing Zoneminder for the first time (Ubuntu), but have found the camera I'm using (Logitech Qiuck Cam Express) doesn't handle different lighting conditions well. In normal daylight the picture is whited out; if I try and change the settings i.e Contrast and/or Brightness it will work for a brief second before reverting back to its original setting. I've read somewhere this is due to the linux driver and probably there is no fix.
I was wondering if some people could suggest a good USB camera which works well (auto light adjustment) with Zoneminder?
USB Camera suggestion
from my personal experience:
buy a usb webcam with a ccd sensor, not with a cmos one...
cheap cmos cameras, are crap..
Ye-Olde's Manor - http://ye-olde.net
- zoneminder
- Site Admin
- Contact:
Philips PCVC740K ToUcam Promarcel wrote: which ccd camera do you use?
i'm lucky to have 3-4 of them..
Thanks for the advise, I'm going to checkout the Philips.lewis wrote:Philips PCVC740K ToUcam Promarcel wrote: which ccd camera do you use?
Howerver I'm also thinking that a capture card might be a better option, then I will have a bigger range of cameras to choose from. Any thoughts?
While looking for what webcam to buy I ran into this page:jasont.t wrote: Thanks for the advise, I'm going to checkout the Philips.
http://www.smcc.demon.nl/webcam/
By the sound of it kernel support for philips camera that used the PWC driver might need kernel patching in the future...
For info, I'm a total newb to zoneminder and I wasn't able to get a creative labs P1030 camera to work. But a Logitech quickcam communicate STX works fine once I installed the OV511 driver (which for some reason doesn't come with the SuSE 10.1 distribution)
I don't know how good it would do outside, but in a bright kitchen with a white floor the image initially comes up all washed out then adjusts itself (I suppose zoneminder controls that adjustment, not the camera?)
bruno.
