Optimal way to time lapse with IP cameras?
Posted: Sat Aug 12, 2006 3:17 am
I am using Axis cams right now but I think finding an optimal setting would actually work with any IP camera (I guess).
I am currently using ZM 1.22.2
The thing is, I am trying to "pull" one jpg from each of my Axis cams every 10 seconds (or for the matter trying to find a setting to pull one frame any user specified number of seconds).
The setting that got my setup going on Record Mode is to set Maximum FPS (MFPS) to 0.10 and Alarm Maximum FPS to 0.10 (Under Monitor - General tab). The obvious one (I think) would be to set MFPS and AMFPS to 1 and Frame Skip (Under Misc) to 10, but doing this actually instructs ZM to capture 1 fps
I dont know if there is perhaps a setting I am not aware of to actually tell an IP cam to pull just one (or two or whaterver) frames every 10 (or whatever) seconds.
I bring this up because although I got the cameras to actually capture one frame every ten seconds I feel this not to be elegant, it "feels" like trying to force or fool ZM into capturing one frame by telling it to capture 0.10 of a frame every second
which could cause overhead (which there is none) or perhaps a bunch of other weird errors (that I would like to take care of in another post) and which I think maybe would go away by just plainly instructing ZM to pull just X frame(s) every X second(s) from an IP cam in a more optimal form.
Any ideas?
Regards!
Any ideas?
Regards!
