Here is the output....
Linux version 2.6.16.17.rdm1.smp (
ross@sentrix.local.domain) (gcc version 4.0.1 (4.0.1-5mdk for Mandriva Linux release 2006.0)) #1 SMP Sat May 27 22:19:23 PDT 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff3000 (ACPI NVS)
BIOS-e820: 000000000fff3000 - 0000000010000000 (ACPI data)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
255MB LOWMEM available.
On node 0 totalpages: 65520
DMA zone: 4096 pages, LIFO batch:0
DMA32 zone: 0 pages, LIFO batch:0
Normal zone: 61424 pages, LIFO batch:15
HighMem zone: 0 pages, LIFO batch:0
DMI 2.3 present.
ACPI: RSDP (v000 VIA694 ) @ 0x000f6e10
ACPI: RSDT (v001 VIA694 AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x0fff3000
ACPI: FADT (v001 VIA694 AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x0fff3040
ACPI: DSDT (v001 VIA694 AWRDACPI 0x00001000 MSFT 0x0100000c) @ 0x00000000
ACPI: PM-Timer IO Port: 0x4008
Allocating PCI resources starting at 20000000 (gap: 10000000:efff0000)
Built 1 zonelists
Kernel command line: auto BOOT_IMAGE=Mandriva ro root=301 noapic nolapic acpi=ht nomce splash=silent
bootsplash: silent mode.
mapped APIC to ffffd000 (01221000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 1024 (order: 10, 16384 bytes)
Detected 666.626 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 254944k/262080k available (2123k kernel code, 6592k reserved, 669k data, 244k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 1334.35 BogoMIPS (lpj=667177)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU: After all inits, caps: 0383f9ff 00000000 00000000 00000040 00000000 00000000 00000000
Checking 'hlt' instruction... OK.
CPU0: Intel Pentium III (Coppermine) stepping 03
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs... it is
Freeing initrd memory: 643k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfb290, last bus=1
PCI: Using configuration type 1
ACPI: Subsystem revision 20060127
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI: disabled
PnPBIOS: Disabled
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:01:00.0
PCI: Using IRQ router VIA [1106/0596] at 0000:00:07.0
PCI: Bridge: 0000:00:01.0
IO window: c000-cfff
MEM window: d4000000-d5ffffff
PREFETCH window: d8000000-d87fffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
audit: initializing netlink socket (disabled)
audit(1155610508.880:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Activating ISA DMA hang workarounds.
vesafb: framebuffer at 0xd8000000, mapped to 0xd0880000, using 3750k, total 4096k
vesafb: mode is 800x600x16, linelength=1600, pages=3
vesafb: protected mode interface info at c7d2:0000
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 13182 bytes,<6>...found (800x600, 9805 bytes, v3).
Console: switching to colour frame buffer device 100x37
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 32000K size 1024 blocksize
acx: compiled to use 32bit I/O access. I/O timing issues might occur, such as non-working firmware upload. Report them
running on a little-endian CPU
PCI module v0.4.7 initialized, waiting for cards to probe...
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:07.1
PCI: VIA IRQ fixup for 0000:00:07.1, from 255 to 0
VP_IDE: chipset revision 16
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt82c596b (rev 23) IDE UDMA66 controller on pci0000:00:07.1
ide0: BM-DMA at 0xd000-0xd007, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xd008-0xd00f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
hda: WDC WD205BA, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: CD-ROM 48X/TKU, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 40088160 sectors (20525 MB) w/2048KiB Cache, CHS=39770/16/63, UDMA(66)
hda: cache flushes not supported
hda: hda1 hda2 < hda5 hda6 >
mice: PS/2 mouse device common for all mice
md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: bitmap version 4.39
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <
jketreno@linux.intel.com>
ieee80211_crypt: registered algorithm 'NULL'
Using IPI Shortcut mode
BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
Freeing unused kernel memory: 244k freed
input: AT Translated Set 2 keyboard as /class/input/input0
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.3
PCI: Found IRQ 10 for device 0000:00:07.2
PCI: Sharing IRQ 10 with 0000:00:13.0
uhci_hcd 0000:00:07.2: UHCI Host Controller
uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:07.2: irq 10, io base 0x0000d400
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
usb 1-1: new full speed USB device using uhci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
SCSI subsystem initialized
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
input: ImPS/2 Generic Wheel Mouse as /class/input/input1
libata version 1.20 loaded.
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Linux video capture interface: v1.00
sn9c102: V4L2 driver for SN9C10x PC Camera Controllers v1:1.26
usb 1-1: SN9C10[12] PC Camera Controller detected (vid/pid 0x0C45/0x6028)
usb 1-1: PAS202BCB image sensor detected
usb 1-1: Initialization succeeded
usb 1-1: V4L2 device registered as /dev/video0
usbcore: registered new driver sn9c102
usbcore: registered new driver spca5xx
3rdparty/usb-spca50x/drivers/usb/spca5xx.c: spca5xx driver 00.60.00 registered
EXT3 FS on hda1, internal journal
Adding 3212960k swap on /dev/hda5. Priority:-1 extents:1 across:3212960k
Capability LSM initialized
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bt878: AUDIO driver version 0.0.0 loaded
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected VIA Apollo Pro 133 chipset
agpgart: AGP aperture is 64M @ 0xd0000000
loop: loaded (max 8 devices)
hdc: ATAPI 48X CD-ROM drive, 128kB Cache, DMA
Uniform CD-ROM driver Revision: 3.20
bootsplash: status on console 0 changed to on
Netfilter messages via NETLINK v0.30.
ip_conntrack version 2.4 (2047 buckets, 16376 max) - 232 bytes per conntrack
Removing netfilter NETLINK layer.
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
NET: Registered protocol family 17
e100: Intel(R) PRO/100 Network Driver, 3.5.10-k2-NAPI
e100: Copyright(c) 1999-2005 Intel Corporation
PCI: Found IRQ 5 for device 0000:00:11.0
e100: eth0: e100_probe: addr 0xd8901000, irq 5, MAC addr 00:D0:B7:92:08:F2
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
ip_tables: (C) 2000-2006 Netfilter Core Team
ipt_recent v0.3.1: Stephen Frost <
sfrost@snowman.net>.
http://snowman.net/projects/ipt_recent/
ipt_owner: pid, sid and command matching not supported anymore
parport0: PC-style at 0x378 [PCSPP,TRISTATE]
lp0: using parport0 (polling).
lp0: console ready
PCI: Found IRQ 11 for device 0000:00:10.0
Shorewall:net2all:DROP:IN=eth0 OUT= MAC= SRC=192.168.0.108 DST=224.0.0.251 LEN=70 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=50
Shorewall:net2all:DROP:IN=eth0 OUT= MAC= SRC=192.168.0.108 DST=224.0.0.251 LEN=104 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=84
bootsplash 3.1.6-2004/03/31: looking for picture...<6>...found (800x600, 9805 bytes, v3).
bootsplash: status on console 1 changed to on
bootsplash: status on console 2 changed to on
bootsplash: status on console 3 changed to on
bootsplash: status on console 4 changed to on
bootsplash: status on console 5 changed to on
[guest ~]$
