Current setup for camera is:
NTSC
30fps
320x240
Grey
The ZM trying to connect has these settings
30fps
320x240
grey
ip address
80
/cgi-bin/nph-zms?mode=jpeg&monitor=21&scale=100&maxfps=30
grey
Below is what the current ZM is getting while trying to get images from the remote zm. The remote ZM does display images.
Aug 15 00:51:50 menace-frontend zmc_m3[16642]: INF [Starting Capture]
Aug 15 00:51:50 menace-frontend zmc_m3[16642]: ERR [Captured image does not match expected size, check width, height and colour depth]
Both servers have the same apache and PHP versions. They are also connected the same switch.
apache 2.0.58
php 5.1.4
perl 5.8.8
ZM 1.22.2
