JJTech / Gadspot NC1200 W10 - Image capture error
I have recently bought a NC1200 W10 IP Camera. I have installed the software and configured it, tested and it works fine in Windows.
I have tried capturing the image using IE and Firefox, and both works fine using the information I got from http://www.gadget-spot.co.uk/Downloads/ ... NC1200.txt, specifically
http://{USER_ID}:{PASSWORD}@{CAMERA_IP}/cgi-bin/getimage.cgi?motion=1
or
http://{USER_ID}:{PASSWORD}@{CAMERA_IP}/cgi-bin/getimage.cgi?motion=0
I have sucessfully installed zoneminder 1.22.2 on CENTOS 4. I have tested it with a local usb webcam and it works fine. However when I tried to create a remote source type with the corresponding information above, I got the following error messages.
08/20/06 22:01:23.461618 zmwatch[6687].INF [Watchdog starting]
08/20/06 22:01:23.462583 zmwatch[6687].INF [Watchdog pausing for 30 seconds]
08/20/06 22:01:53.467176 zmwatch[6687].ERR [Can't read 'shared_data:size' from shared memory '7a6d2001/950283': Permission denied]
08/20/06 22:01:53.468057 zmwatch[6687].INF [Restarting capture daemon for IPCom01, shared memory not valid]
08/20/06 22:01:53.816511 zmwatch[6687].INF ['zmc -m 1' started at 06/08/20 22:01:53] at /usr/local/bin/zmwatch.pl line 118
08/20/06 22:02:03.847153 zmwatch[6687].ERR [Can't read 'shared_data:size' from shared memory '7a6d2001/950283': Permission denied]
08/20/06 22:02:03.847658 zmwatch[6687].INF [Restarting capture daemon for IPCom01, shared memory not valid]
08/20/06 22:02:04.195777 zmwatch[6687].INF ['zmc -m 1' starting at 06/08/20 22:02:04, pid = 6745] at /usr/local/bin/zmwatch.pl line 118
If anyone has sucessfully installed and captured image (both JPEG and MPEG) from a NC1200 W10 IP Camera to please share your expert knowledge and help me fix my issue.
BTW, ZoneMinder is a great software so Cheers to you all brilliant people who build and supportit!!!
G'day!
or
G'day!
- zoneminder
- Site Admin
- Contact:
Your problem is that your shared memory is set up such that the applications can't access it. Sometimes this happens when you test a bit as root and then start ZM as apache. It cannot get into the existing shared memory.
If you do 'ipcs -m' you should see a listing of the segments. I would stop ZM, check what segments (if any) are left (these will all have a key that starts 0x7a6d20). Delete them using ipcrm and then restart ZM. Hopefully that will get rid of your problem, which is not directly related to your cameras at all.
Phil
Hi Phil,
Thanks for your advice. It has fixed the initial issue with the shared memory and it is now gone. However there is no picture coming up, it is either white (blank) or plain black, the source info on the webconsole is red. I have provided some information that might be of use to diagnose this other issue.
The zmu result of the NC1200 W10
zmu -q -v -m 1
Monitor 1(IPCom01)
Type : Remote
Host : <user:password>@<camera-ip>
Port : 81
Path : /cgi-bin/getimage.cgi?motion=1
Width : 320
Height : 240
Palette : 4
Colours : 3
Event Prefix : Event-
Label Format : %%s - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 200
Warmup Count : 5
Pre Event Count : 10
Post Event Count : 10
Alarm Frame Count : 1
Section Length : 600
Maximum FPS : 10.00
Alarm Maximum FPS : 5.00
Reference Blend %ge : 7
Track Motion : 0
Function: 3 - Motion Detection
Zones : 1
Label : All
Type: 1 - Active
Shape : 4 points
0: 0,0
1: 319,0
2: 319,239
3: 0,239
Alarm RGB : ff0000
Check Method: 3 - Blobs
Min Pixel Threshold : 25
Max Pixel Threshold : 0
Min Alarm Pixels : 2306
Max Alarm Pixels : 57601
Filter Box : 3,3
Min Filter Pixels : 2306
Max Filter Pixels : 57601
Min Blob Pixels : 1534
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
Started zmpkg.pl under the apache account and it seems to be running.
ipcs -m
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x7a6d2001 1409025 apache 700 46082244 2
0x7a6d2002 1441808 apache 700 3042244 2
zmdc.log file contains:
08/22/2006 20:24:55.002803 zmdc[26774].INF [Starting pending process, zmc -m 1]
08/22/2006 20:24:55.005310 zmdc[26774].INF ['zmc -m 1' starting at 06/08/22 20:24:55, pid = 27408]
08/22/2006 20:24:55.006774 zmdc[27408].INF ['zmc -m 1' started at 06/08/22 20:24:55]
08/22/2006 20:24:57.276023 zmdc[26774].ERR ['zmc -m 1' exited abnormally, exit status 255]
08/22/2006 20:30:17.039247 zmdc[26774].INF [Starting pending process, zmc -m 1]
08/22/2006 20:30:17.041477 zmdc[27673].INF ['zmc -m 1' started at 06/08/22 20:30:17]
08/22/2006 20:30:17.043322 zmdc[26774].INF ['zmc -m 1' starting at 06/08/22 20:30:17, pid = 27673]
08/22/2006 20:30:19.302466 zmdc[26774].ERR ['zmc -m 1' exited abnormally, exit status 255]
I have throttled down the IP Camera to 1 fps only because I thought that zoneminder could not keep up.
Any idea/solution/advice is very much appreciated.
Thanks,
OGM
zmu -q -v -m 1
Monitor 1(IPCom01)
Type : Remote
Port : 81
Width : 320
Height : 240
Palette : 4
Colours : 3
Label Coord : 0,0
Warmup Count : 5
Maximum FPS : 10.00
Track Motion : 0
Zones : 1
Label : All
Type: 1 - Active
Shape : 4 points
0: 0,0
1: 319,0
2: 319,239
3: 0,239
Alarm RGB : ff0000
Filter Box : 3,3
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
ipcs -m
Thanks,
OGM
- zoneminder
- Site Admin
- Contact:
Try these links instead;
(Assuming you're using passwords instead of default non-pass. If you're not using passwords, remove the "user:passwd@" from both strings)
wget http://user:passwd@camera.ip/GetData.cgi
For mjpeg
http://user:passwd@camera.localdomain/Jpeg/CamImg.jpg
For jpg.
In both cases, ensure your ZM sizes are EXACTLY what you've set on the camera.
For mjpeg
For jpg.
Thanks Phil, I did what you have suggested and still I'm getting the same error messages in zmdc.log. I think the issue is nothing to do with zoneminder. I have come to this conclusion because capturing the image/picture from Linux does not seem to work. I have used both firefox and wget in windows and they both worked but not in linux... it is strange. Anyway I will keep on testing.
Thanks Flash_, I did what you have suggested before I came to find out from gadspot uk that the NC1200 has a different API (you may find the link in the thread).
G'day
G'day
See my user contrib thread on the zonemider bug that affects passwords on some video servers... It may help.
mycal
mycal
Flash_ wrote:Try these links instead;
For mjpeg
For jpg.
Hi mycal,
I did what you have suggested and still it did not work. Anyway I have add ed more information about the IP cam.
I have done,
telnet myipcam 80
And it returns,
HTTP/1.0 500 Server Error
Date: Sat, 01 Jan 2000 03:00:07 GMT
Server: WYM/1.0
Connection: close
Content-Type: text/html
<HTML><HEAD><TITLE>500 Server Error</TITLE></HEAD>
<BODY><H1>500 Server Error</H1
The server encountered an internal error and could not complete your request.
BODY></HTML>
Connection to host lost.
Also, the image's html source code when viewed in Internet Explorer.
<tr>
<td bgcolor="#4d5c7f" height="578" width="727">
<div align="center">
<object id="VCView1" data="data:application/x-oleobject;base64,zfblH5B0KESeeYMOjMVbiwADAADYEwAA2BMAAA==" classid="clsid:1FE5F6CD-7490-4428-9E79-830E8CC55B8B" codebase="./control/VCViewAtl.cab#version=1,0,0,6" height="240" width="320">
</object>
</div>
</td>
</tr>
G'day
I have done,
telnet myipcam 80
And it returns,
Server: WYM/1.0
Connection: close
BODY></HTML>
<tr>
</object>
</div>
</td>
</tr>
G'day
your not getting jpegs of this camera, it looks like your viewing a webpage
James Wilson
My mistake, I should have explain what I intend them to do.
The first one, the telnet stuff, I wanted to know what sort of http version is running on it. I found that is it version 1.0.
The second one, I just wanted to know how the PC software that comes along with the IP Camera renders the image. I found VCViewAtl.cab - I don't know if this is a Java or ActiveX file.
I thought that by posting these information would help learn more about the NC1200 W10 or GS 1200 W10 IP cameras.
Anyway I could capture the MPEG/JPEG using wget and firefox through the location below
or
in Windows but not in Centos 4, Ubuntu 5, and Fedora Core 5.
My next plan is to install WINE and the IP camera's PC software and let latter capture the image and then let Zoneminder pick it up locally.
G'day
or
G'day
Some more log updates
Executing Wget for windows works fine but not in Linux.
wget http://<hostname>/cgi-bin/getimage.cgi?motion=0 -O pic01.jpg -d
DEBUG output created by Wget 1.10.1 on mingw32.
--14:53:22-- http://<hostname>/cgi-bin/getimage.cgi?motion=0
=> `pic01.jpg'
Resolving <hostname>... seconds 0.00, x.x.x.x
Caching <hostname> => x.x.x.x
Connecting to <hostname>... seconds 0.00, connected.
Created socket 740.
Releasing 0x003f61f8 (new refcount 1).
---request begin---
GET /cgi-bin/getimage.cgi?motion=0 HTTP/1.0
User-Agent: Wget/1.10.1
Accept: */*
Authorization: Basic 62N1c2VyOnNob3cwMTI6
Host: <hostname>
Connection: Keep-Alive
---request end---
HTTP request sent, awaiting response...
---response begin---
HTTP/1.0 200 OK
Date: Sat, 01 Jan 2000 02:07:08 GMT
Server: WYM/1.0
Keep-Alive: timeout=1, max=108000
Content-Type: application/x-javascript
Content-Length: 22246
Last-Modified: Sat, 01 Jan 2000 02:07:08 GMT
---response end---
200 OK
Registered socket 740 for persistent reuse.
Length: 22,246 (22K) [application/x-javascript]
100%[====================================>] 22,246 11.48K/s
14:53:24 (11.46 KB/s) - `pic01.jpg' saved [22246/22246]
You will notice that Content-Type is application/x-javascript and I don't know if it is supported by ZoneMinder.
In linux
DEBUG output created by Wget 1.10.2 (Red Hat modified) on linux-gnu.
--15:14:12-- http://<hostname>/cgi-bin/getimage.cgi?motion=0
=> `pic01.jpg'
Resolving ngm.id.au... x.x.x.x
Caching ngm.id.au => x.x.x.x
Connecting to ngm.id.au|x.x.x.x ... connected.
Created socket 4.
Releasing 0x0a010880 (new refcount 1).
---request begin---
User-Agent: Wget/1.10.2 (Red Hat modified)
Accept: */*
Host: <hostname>
---request end---
HTTP request sent, awaiting response... <<<< Control C to stop because it keeps on going >>>>
=> `pic01.jpg'
Created socket 740.
---request begin---
Accept: */*
Host: <hostname>
---request end---
HTTP/1.0 200 OK
Server: WYM/1.0
---response end---
200 OK
In linux
=> `pic01.jpg'
Created socket 4.
---request begin---
Accept: */*
Host: <hostname>
---request end---
That's really odd.
Suggestions:
Something's wrong with the networking on the linux box. Does it work ok in all other regards? (wgetting other various stuff from your intranet and the internet)
Wget's cache is screwy. I saw this recently where curl would get to a domain and wget would not. Give curl a try.
Talk to Gadspot UK. I had a technically competent reply when I asked them a question by email once, got to be worth a go.
Suggestions:
Tech Support
If you pass me some details in an attachment (Text file) as basic as possible, I can contact the designers (China!) and see what we get back.
Sorry that I do not have a dircet answer.
Also, if you log this issue on our support system, we can track it to conclusion.
www.gadget-spot.co.uk/support
