Page 1 of 1
Deleting Events?
Posted: Sun Aug 20, 2006 8:10 pm
by Maxxarcade
Is there a way to clear ALL events (except archive) with one button? Sometimes it takes me 15 minutes to clear all the events going a page at a time. Am I overlooking something?
Posted: Sun Aug 20, 2006 9:19 pm
by zoneminder
Curently there isn't apart from either selecting all events (click on 'view all') or setting up a filter. This is on the TBD list tho.
Posted: Fri Sep 01, 2006 4:31 pm
by johabba
what is the best way to delete events w/out screwing up the database? After removing them from the filesystem, would we need to run an SQL cmd to let the database know all the events are gone?
Posted: Wed Sep 06, 2006 5:49 pm
by zoneminder
If you either delete them from the DB or from the filesystem, zmaudit.pl will come along and tidy up and make everything consistent again. Though it might take a little while if you have a lot of them.
Posted: Tue Sep 12, 2006 2:33 am
by Maxxarcade
Well, I can't get my PurgeWhenFull filter to work, I had it set to 80%, and now the disk shows 82% full with about 8700 events. I can't select "view all" because it says Cannot Find Server. What should I do to clear out all the events before the disk gets completely full? There's no way I can sit here for hours and delete them a page at a time...
Posted: Tue Sep 12, 2006 2:52 am
by Maxxarcade
Nevermind, it started deleting things after I played with it a bit. Problem is, it cleared the archive out as well, even though I selected "unarchived only". I think I just need to learn how to use filters better.
