Change to Modect requires restart with bt878 card
Posted: Mon Aug 21, 2006 5:21 am
Hi all,
I've been slowly configuring a ZoneMinder server and had it working well with my 2 DLink 4 channel video servers. It is a very impressive piece of software and I shall certainly be making a donation once I have everything running smoothly.
Now...I've decided to relocate a camera, and due to "logistical issues" the easiest way to do this was to get a cheap 4 channel PCI card for the server, but I'm experiencing some strange behaviour that means I have to restart ZoneMinder for MODECT to work properly.
The card is a generic bt878 clone bought from eBay and works fine in Monitor mode with card=77 in modprobe.conf. I'm using an install of Ross's Mandriva LiveCD.
There seem to be 2 sets of symptoms.
(1) On changing the camera on /dev/video0 to Modect from Monitor, no motion is detected unless zoneminder is restarted. Syslog:
(2) With the camera on /dev/video0 set to modect (and working correctly after a ZM restart), after changing a network camera from Monitor to Modect, motion is detected but the alarm does not terminate when movement ceases: the state has to be forced back to Monitor or None. Syslog:
I've tried all sorts of things to get rid of this behaviour:
- thinking it might be the AMD64 architecture I re-installed on a P4
- thinking it might be an IRQ conflict I moved the card to various PCI slots in both machines
- thinking it might be the distro I rebuilt the server using Ubuntu 6.06
- I've tried a number of different card=XX: 77, 89, 103, 105, with and without tuner=-1.
The result was the same each time.
The output from dmesg all looks normal, as does scanpci. The network cameras work fine on their own or when the local camera is set to none. It plainly isn't the install or the hardware so could the card be a dud?
Apologies for the long post but I've run out of ideas. Can anyone else shed any light on this?
Thanks, Goatcatcher
EDIT: added info
The "prealarm state" never seems to escale to a full alarm. The suspicious line here seems to be "INF [Got signal (Hangup), reloading]" which does not appear after the ZM restart.Aug 20 00:33:38 zm zmdc[5623]: INF ['zmupdate.pl -c' started at 06/08/20 00:33:38]
Aug 20 00:33:38 zm zmdc[5582]: INF ['zmupdate.pl -c' starting at 06/08/20 00:33:38, pid = 5623]
Aug 20 00:33:39 zm Update agent starting at 06/08/20 00:33:39
Aug 20 00:34:04 zm zmdc[5582]: INF ['zmc -d /dev/video0' already running at 06/08/20 00:33:37, pid = 5605]
Aug 20 00:34:04 zm zmdc[5670]: INF ['zma -m 1' started at 06/08/20 00:34:04]
Aug 20 00:34:04 zm zmdc[5582]: INF ['zma -m 1' starting at 06/08/20 00:34:04, pid = 5670]
Aug 20 00:34:04 zm zma_m1[5670]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 00:34:04 zm zma_m1[5670]: INF [In mode 3/1, warming up]
Aug 20 00:34:04 zm zma_m1[5670]: INF [Got signal (Hangup), reloading]
Aug 20 00:34:06 zm zma_m1[5670]: INF [Cam_1: 14 - Processing at 3.50 fps]
Aug 20 00:34:08 zm zma_m1[5670]: INF [Cam_1: 019 - Gone into prealarm state]
Aug 20 00:34:08 zm zma_m1[5670]: INF [Cam_1: 21 - Processing at 3.50 fps]
Aug 20 00:34:10 zm zma_m1[5670]: INF [Cam_1: 28 - Processing at 3.50 fps]
Aug 20 00:34:12 zm zma_m1[5670]: INF [Cam_1: 35 - Processing at 3.50 fps]
Aug 20 00:34:14 zm zma_m1[5670]: INF [Cam_1: 42 - Processing at 3.50 fps]
Aug 20 00:34:16 zm zma_m1[5670]: INF [Cam_1: 49 - Processing at 3.50 fps]
Aug 20 00:34:18 zm zma_m1[5670]: INF [Cam_1: 56 - Processing at 3.50 fps]
Aug 20 00:34:20 zm zma_m1[5670]: INF [Cam_1: 63 - Processing at 3.50 fps]
Aug 20 00:34:22 zm zma_m1[5670]: INF [Cam_1: 70 - Processing at 3.50 fps]
Aug 20 00:34:24 zm zma_m1[5670]: INF [Cam_1: 77 - Processing at 3.50 fps]
Aug 20 00:34:26 zm zma_m1[5670]: INF [Cam_1: 84 - Processing at 3.50 fps]
Aug 20 00:34:28 zm zma_m1[5670]: INF [Cam_1: 91 - Processing at 3.50 fps]
Aug 20 00:34:30 zm zma_m1[5670]: INF [Cam_1: 98 - Processing at 3.50 fps]
Aug 20 00:34:31 zm zma_m1[5670]: INF [Cam_1: 102 - Gone into prealarm state]
Aug 20 00:34:32 zm zma_m1[5670]: INF [Cam_1: 105 - Processing at 3.50 fps]
Aug 20 00:34:34 zm zma_m1[5670]: INF [Cam_1: 112 - Processing at 3.50 fps]
Aug 20 00:34:36 zm zma_m1[5670]: INF [Cam_1: 119 - Processing at 3.50 fps]
Aug 20 00:34:37 zm zmpkg[5776]: INF [Command: restart]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmaudit.pl -c' stopping at 06/08/20 00:34:38]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmaudit.pl -c' crashed, signal 14]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zma -m 1' stopping at 06/08/20 00:34:38]
Aug 20 00:34:38 zm zma_m1[5670]: INF [Got signal (Terminated), exiting]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zma -m 1' exited normally]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmfilter.pl ' stopping at 06/08/20 00:34:38]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmfilter.pl ' crashed, signal 14]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmupdate.pl -c' stopping at 06/08/20 00:34:38]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmupdate.pl -c' crashed, signal 14]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmc -d /dev/video0' stopping at 06/08/20 00:34:38]
Aug 20 00:34:38 zm zmc_dvideo0[5605]: INF [Got signal (Terminated), exiting]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmc -d /dev/video0' exited normally]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmwatch.pl ' stopping at 06/08/20 00:34:38]
Aug 20 00:34:38 zm zmdc[5582]: INF ['zmwatch.pl ' crashed, signal 14]
Aug 20 00:34:48 zm zmdc[5582]: INF [Server shutdown at 06/08/20 00:34:48]
It is interesting to note that this time the "[Got signal (Hangup), reloading]" refers to the network camera, and, although an alarm is triggered, a segmentation fault occurs. The zma -m 2 process restarts itself, and all the time the alarm is still continuing.Aug 20 00:51:55 zm zmdc[7058]: INF ['zmc -m 2' started at 06/08/20 00:51:55]
Aug 20 00:51:55 zm zmdc[6970]: INF ['zmc -m 2' starting at 06/08/20 00:51:55, pid = 7058]
Aug 20 00:51:55 zm zmc_m2[7058]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 00:51:55 zm zmc_m2[7058]: INF [Starting Capture]
Aug 20 00:51:56 zm zmdc[7063]: INF ['zma -m 2' started at 06/08/20 00:51:56]
Aug 20 00:51:56 zm zmdc[6970]: INF ['zma -m 2' starting at 06/08/20 00:51:56, pid = 7063]
Aug 20 00:51:56 zm zma_m2[7063]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 00:51:56 zm zma_m2[7063]: INF [In mode 3/1, warming up]
Aug 20 00:51:56 zm zma_m2[7063]: INF [Got signal (Hangup), reloading]
Aug 20 00:51:57 zm zma_m2[7063]: INF [Cam_2: 7 - Processing at 7.00 fps]
Aug 20 00:51:59 zm zma_m2[7063]: INF [Cam_2: 14 - Processing at 3.50 fps]
Aug 20 00:52:00 zm zma_m1[6997]: INF [Cam_1: 106 - Gone into prealarm state]
Aug 20 00:52:01 zm zma_m1[6997]: INF [Cam_1: 107 - Gone into alarm state]
Aug 20 00:52:01 zm zma_m1[6997]: INF [Cam_1: 110 - Gone into alert state]
Aug 20 00:52:01 zm zma_m2[7063]: INF [Cam_2: 21 - Processing at 3.50 fps]
Aug 20 00:52:03 zm zma_m2[7063]: INF [Cam_2: 28 - Processing at 3.50 fps]
Aug 20 00:52:04 zm zma_m1[6997]: INF [Cam_1: 120 - Left alarm state (523) - 24(4) images]
Aug 20 00:52:06 zm zma_m2[7063]: INF [Cam_2: 35 - Processing at 2.33 fps]
Aug 20 00:52:07 zm zma_m2[7063]: INF [Cam_2: 42 - Processing at 7.00 fps]
Aug 20 00:52:09 zm zma_m2[7063]: INF [Cam_2: 49 - Processing at 3.50 fps]
Aug 20 00:52:11 zm zma_m2[7063]: INF [Cam_2: 56 - Processing at 3.50 fps]
Aug 20 00:52:13 zm zma_m2[7063]: INF [Cam_2: 63 - Processing at 3.50 fps]
Aug 20 00:52:15 zm zma_m2[7063]: INF [Cam_2: 70 - Processing at 3.50 fps]
Aug 20 00:52:18 zm zma_m2[7063]: INF [Cam_2: 77 - Processing at 2.33 fps]
Aug 20 00:52:20 zm zma_m2[7063]: INF [Cam_2: 84 - Processing at 3.50 fps]
Aug 20 00:52:22 zm zma_m2[7063]: INF [Cam_2: 91 - Processing at 3.50 fps]
Aug 20 00:52:23 zm zma_m2[7063]: INF [Cam_2: 096 - Gone into prealarm state]
Aug 20 00:52:24 zm zma_m2[7063]: INF [Cam_2: 98 - Processing at 3.50 fps]
Aug 20 00:52:26 zm zma_m2[7063]: INF [Cam_2: 105 - Processing at 3.50 fps]
Aug 20 00:52:27 zm zma_m2[7063]: INF [Cam_2: 112 - Processing at 7.00 fps]
Aug 20 00:52:28 zm zma_m2[7063]: INF [Cam_2: 113 - Gone into prealarm state]
Aug 20 00:52:30 zm zma_m2[7063]: INF [Cam_2: 119 - Processing at 2.33 fps]
Aug 20 00:52:32 zm zma_m2[7063]: INF [Cam_2: 126 - Processing at 3.50 fps]
Aug 20 00:52:34 zm zma_m2[7063]: INF [Cam_2: 133 - Processing at 3.50 fps]
Aug 20 00:52:36 zm zma_m2[7063]: INF [Cam_2: 140 - Processing at 3.50 fps]
Aug 20 00:52:36 zm zmfilter[7001]: INF [Executing '/usr/lib/zm/bin/zmeventdump 1/522']
Aug 20 00:52:36 zm zmfilter[7001]: INF [Executing '/usr/lib/zm/bin/zmeventdump 1/523']
Aug 20 00:52:38 zm zma_m2[7063]: INF [Cam_2: 147 - Processing at 3.50 fps]
Aug 20 00:52:40 zm zma_m2[7063]: INF [Cam_2: 154 - Processing at 3.50 fps]
Aug 20 00:52:42 zm zma_m2[7063]: INF [Cam_2: 161 - Processing at 3.50 fps]
Aug 20 00:52:44 zm zma_m2[7063]: INF [Cam_2: 168 - Processing at 3.50 fps]
Aug 20 00:52:45 zm zma_m2[7063]: INF [Cam_2: 174 - Gone into prealarm state]
Aug 20 00:52:46 zm zma_m2[7063]: INF [Cam_2: 175 - Processing at 3.50 fps]
Aug 20 00:52:48 zm zma_m2[7063]: INF [Cam_2: 182 - Processing at 3.50 fps]
Aug 20 00:52:50 zm zma_m2[7063]: INF [Cam_2: 189 - Processing at 3.50 fps]
Aug 20 00:52:50 zm zma_m2[7063]: INF [Cam_2: 191 - Gone into alarm state]
Aug 20 00:52:50 zm zma_m2[7063]: ERR [Got signal (Segmentation fault), crashing]
Aug 20 00:52:50 zm zma_m2[7063]: ERR [Signal address is 0x1818171b, from 0x8063e0e ]
Aug 20 00:52:50 zm zma_m2[7063]: ERR [Backtrace: /usr/lib/zm/bin/zma [0x8063e0e]]
Aug 20 00:52:50 zm zma_m2[7063]: ERR [Backtrace: /usr/lib/zm/bin/zma(__gxx_personality_v0+0x394) [0x804acb4]]
Aug 20 00:52:50 zm zma_m2[7063]: ERR [Backtrace: /lib/tls/libc.so.6(__libc_start_main+0xd0) [0xb7809e40]]
Aug 20 00:52:50 zm zma_m2[7063]: ERR [Backtrace: /usr/lib/zm/bin/zma(__gxx_personality_v0+0xa1) [0x804a9c1]]
Aug 20 00:52:50 zm zma_m2[7063]: INF [Backtrace complete]
Aug 20 00:52:50 zm zmdc[6970]: ERR ['zma -m 2' exited abnormally, exit status 11]
Aug 20 00:52:50 zm zmdc[6970]: INF [Starting pending process, zma -m 2]
Aug 20 00:52:50 zm zmdc[7180]: INF ['zma -m 2' started at 06/08/20 00:52:50]
Aug 20 00:52:50 zm zmdc[6970]: INF ['zma -m 2' starting at 06/08/20 00:52:50, pid = 7180]
Aug 20 00:52:50 zm zma_m2[7180]: INF [Debug Level = 0, Debug Log = <none>]
Aug 20 00:52:50 zm zma_m2[7180]: INF [In mode 3/1, warming up]
Aug 20 00:53:17 zm zmpkg[7277]: INF [Command: stop]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zma -m 2' stopping at 06/08/20 00:53:17]
Aug 20 00:53:17 zm zma_m2[7180]: INF [Got signal (Terminated), exiting]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zma -m 2' exited normally]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zmc -m 2' stopping at 06/08/20 00:53:17]
Aug 20 00:53:17 zm zmc_m2[7058]: INF [Got signal (Terminated), exiting]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zmc -m 2' exited normally]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zmupdate.pl -c' stopping at 06/08/20 00:53:17]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zmupdate.pl -c' crashed, signal 14]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zmfilter.pl ' stopping at 06/08/20 00:53:17]
Aug 20 00:53:17 zm zmdc[6970]: INF ['zmfilter.pl ' crashed, signal 14]
Thanks, Goatcatcher
EDIT: added info
