Image brightness fluctuations
Posted: Sat Nov 15, 2003 9:43 am
I've just set up ZoneMinder (0.9.15) on Suse 8.2 and it all appers to be working apart from a problem with extreme image brightness fluctuations from frame to frame (viewed using Mozilla 1.4). The vieo card is a GrandTec Video Capture card (4-channel device using the BT878 chipset) and the image looks stable when checked with KWinTV. However, the flucuations are so extreme in ZM that it is virtually impossible to define meaningful monitors and zones. Any thoughts?
Cheers,
Norman
PS - Very impressed with the software otherwise!
Cheers,
Norman
