hey guys, i am running 4 Sony SNC-M1W cameras over landline (not using the wireless) ... i can have all running in level 5 image quality (highest setting) at 320x240 but when i switch them to 640x480 i can only run 2 cameras and they have to be set to the lowest image quality to work otherwise i get a black screen where the image stream should be ...
i already increased the shared memory level which fixed my initial problem where none of them worked no matter what ...
anyone have any ideas ?
problem running more than 2 cameras in 640x480 or in any...
well it might be an idea to put a 640x480 jpeg on your webserver and ref thaton a test monitor to see if its a machine or camera issue
James Wilson
While I'm installing a fresh 1.22.2 to try to run all the Sonys in 640x480, here's a question: could it be your browser? I rememebr a problem I had when I went to 8 monitors - Netscape only showed 4 streams.
Then I read a post where it recommended changing the number of allowed simultaneous connections to the browser.
That's accomplished by entering "about:config" as the url location; this shows all the settable parameters. Find the networking/connection settings, and change the simultaneous connections and/or streams to, say, 75.
I'll try to find the post...
AHA!
http://www.zoneminder.com/forums/viewto ... wser+cache
and
http://www.zoneminder.com/forums/viewto ... cfrequency
Maybe this will help?
and
i already set all those parameters in firefox but i am glad you reminded me about that config page ... i think you are onto something and it really might be only a issue with the browser ... i'll double check the settings when i get into work tomorrow and report back ...
thanks for the great ideas guys ... i was having trouble finding a new point to start trouble shooting.
Camera Configs
I have a Sony SNC-M1W and am wondering what settings you used to get the cameras working in 640 x 480 mode. I am having difficulty getting this camera to work at all in ZM 1.22.2.
