zm manual
captain_morgan
zm manual
Post by captain_morgan »
anyone know the address for the zoneminder manual? i found it and downloaded it once before, but since then, my computer crashed and i can't find where i saved it... it was a referance describing the various things that could be done with the web interface.
voronwe
Post by voronwe »
Hi Captain_Morgan
Is this the link you where looking for ???
Best Regards
Tom Stage
captain_morgan
no, that's the readme. i found an html manual about the web interface, but i can't remember how i found it. thanks fo the post.
zoneminder
Site Admin
Post by zoneminder »
Are you thinking of anything to do with the LiveCD version or just the regular one?
Phil
captain_morgan
the regular one, i guess. it realy had nothing to do with the installation of zm, just the web interface. it explained all of the settings.
zoneminder
Site Admin
Hmmm, I haven't written one with pictures in so I guess it was something contributed. I will have a search and see what I can find.
Phil
captain_morgan
yes, you're right, it wasn't yours; it was written by someone else. i just can't remember where i found it. i did a search for manual, but it came up with all kinds of stuff, and i can't find anything in the wiki. i found it realy helpful in explaining a lot of the setting in the web interface... i just can't recall where i found it. in advance, thanks for the help.
i'm such a dumbass it's under documentation. i must have overlooked it...
download
R2D2
Post by R2D2 »
How can i open the "zm_user_manual" file???
zoneminder
Site Admin
If you are on Windows, you can use WinRar or possible even WinZip.
Phil
R2D2
Post by R2D2 »
zoneminder wrote:If you are on Windows, you can use WinRar or possible even WinZip.
thx :D
cu
R2D2
m00njal
Post by m00njal »
sweet manual, thanks
