Hi to all!
How can I activate authentication mode ? I want to use username and password to access my zoneminder system, but at the end of my installation I have a system with no authentication... how can I do?
Thanks!
Alessandro
How can i activate authentication mode?
please read the docs, phil takes the time to create them and it is searchable,
James Wilson
Alessandro,
As James points out, it is in the docs. However, the topic does not jump out at you, particularly if English might not be your mother tongue.
Authentication is referred to in line 2 of section 8. Tutorial of the html doc. It is a system option accessed by clicking on options in the Zoneminder initial screen. Then you can toggle ZM_OPT_USE_AUTH.
-Robert
-Robert
rw you are a patient man lol
Cheers
Cheers
James Wilson
