Unable to record...
cvsvs
Unable to record...
Post by cvsvs »
Hi ,
I am unable to record any events; the events are created with zero bytes. when I open an event , "Can't open file: 'Frames.MYD'. (errno: 145) " error appears.
The zmaudit log says:
DBD::mysql::st execute failed: Can't open file: 'Frames.MYD'. (errno: 145) at /usr/lib/zm/bin/zmaudit.pl line 396.
Can't execute: Can't open file: 'Frames.MYD'. (errno: 145) at /usr/lib/zm/bin/zmaudit.pl line 396.
would appreciate if someone can assist. ( I have re-started MySql and also ZM , but no luck..)
Rgds
jameswilson
Post by jameswilson »
your db is currupt or your hd is dying. You need to do a mysqlcheck, if you search for the command you will find posts on it
James Wilson
