Using live view of axis
dmarouane
Post by dmarouane »
hello
I am using zoneminder with two camera IP (Axis) it is possible to use axis live view from the web becouse is better then Zoneminder.
zoneminder
Site Admin
Post by zoneminder »
You can access the Axis interface at any time regardless of whether you are using ZM with it. The only limitation would be if you had configured it for one 1 continguous user to view streams at once but I think by default it allows more than this.
Phil
Flash_
Post by Flash_ »
You're right. Axis's default is to 20 simultaneous clients on the 205, 206, 207w and 211's that I've used.
dmaroune - if you want more than one stream, again - bypassing ZM is the better way (puts less stress on the server). Look here; http://www.zoneminder.com/forums/viewtopic.php?t=5809
