I have seen several posts regarding issues with SATA drives and LiveCD. I think I am having an issue. The CD boots fine but when I want to install to disks I can't set partitions because it does not see the disks.
I have a brand new Dell 9150. If anyone has any advice on how to fix this I would greatly apprecaite it.
Josh
LiveCD and SATA problems
A machine that supports SATA drives.Hi, what would you need to troubleshoot? A SATA drive?
I'm reasonably certain that all the required kernel modules are included. I'm using a kernel rebuilt from the PClinuxOS distrib. You might try booting PClinuxOS on your hardware and see if it works. I suspect updated hardware detection and config scripts are needed.A workaround would be to boot from a kernel which supports sata drives/drivers(!)
Any news ?
I'm having trouble with this .. btw it's a SIS chipset
but should work, because it works on the same board using an IDE drive.
All seems to be detected but it says after detecting the hardware: Error on SCSI w700 :/
btw i can mount the hd as a scsi drive and even partition etc on fdisk at /dev/sda
What can i do ?
motherboard is a p4m800
Taz
What can i do ?
Taz
