Zones
Simon
Zones
Post by Simon »
when creating a zone is it better to minimize the number of points used? does it have any impact on performance?
thankyou
zoneminder
Site Admin
Post by zoneminder »
In general yes and no. Though in practice the difference is likely to be negligible as the polygons are resolved to (effectively) bitmaps on startup so it make take a fraction longer to get running but no slower in normal operation. The exception to this is where you have a complex zone which encloses non-zone space. This will take a longer to run and should be split into two or more parts.
For example
is ok, but
should be split into a left and right zone, for optimum performance, though it will work as is.
Phil
jameswilson
Post by jameswilson »
Phil just a suggestion as i didnt know this and have some quite complicated shapes now!!! lol, can someone who knows how zones work do a quick guidlines sheet? just a thought
James Wilson
zoneminder
Site Admin
It's not the end of the world having zones this shape but it will iterate across the contained empty areas even if it won't actually check them.
I do plan to remove this issue in the future but it's not high priority and only really affects things if a horizontal slice contains empty areas, verttical slices aren't a problem at all.
Phil
Flash_
Post by Flash_ »
Don't you just hate it when you've got the zones all set up and just /perfect/ then somebody comes along and nudges the camera?
liderbugzm
Multi point poly
Post by liderbugzm »
This post comes the closest, then not quite. My question is can I change the number of points for a zone poly? From 4 to 6? Haven't found a config to do it. Would it cause problems? Or does one just make 3 or 4 polys? IE. One of my cams has a windsock that I would like to exclude. Hmmm, nother question - would it be possible to make a not-zone. Do a All-zone and a windsock exclude zone?
cordel
Post by cordel »
That is covered in the README:
http://www.zoneminder.com/fileadmin/dow ... c151468571
Regards,
Corey
