I am looking to add a camera to a security gate and I am just starting to do my homework. I came across the GS 1600 http://www.gadspot.com/product_info.php?products_id=32.
Anyone have any experience with this one or could anyone make a recommendation of another camera with simular specs and price?
Thanks in advance.
Anyone have any experience with Gadspt GS 1600H?
If you search the forums for gadspot you'll find quite a lot of information, especially http://www.zoneminder.com/forums/viewto ... ht=gadspot
Thanks. I searched on all variations fof "GS1600" since I was looking for model specific information without a single hit, so it appeared to not be covered.
If it is specifcally covered by name they maybe the administrators should check out the search engine for problems.
Edit:
It seems you have to have a perfect match to get a hit. GS1600H gets a hit to your link. GS 1600, 1600, GS 1600H are all misses.
Thanks for pointing I have to have an exact match to what the poster used.
Edit:
