I have just been asked to take over a zoneminder server (the last admin left). The disk is 100% full and is causing mysql to malfunction and so I can't log in to the web interface (Yes I'm sure I'm using the right username and pw)
I have read the FAQ regarding "purgewhenfull" but it only explains howto enable that option through the web interface.
Can anyone give me any tips on how I can free up some space on this server? Can I delete some jpegs/events (and if so, where are they located, as I'd like to copy them to another server first).
Are all the jpeg/events stored in a mysql database?
Thanks.
Disk is full and I can't log in
You can remove the folder with the event id's under /event/[camid] to free up space. where it is located depends on where the person whom installed ZM desided to locate them but the default is under /var/www/html/event/[camid]/ but of course that depends on your distro (above is Redhat/Fedora/CentOS).
Assuming your using 1.22.x since thats the forum you posted you should be able to check /etc/zm.conf (again assuming the the person whom compiled zm set the config file to be at that location) to see where the event jpegs are located.
Cheers,
Corey
Cheers,
Corey
