Cheap 4/8/16 port card on eBay
2tomcats
Post by 2tomcats »
Hi all,
i recently bought this card on ebay (german seller, ships worldwide):
http://cgi.ebay.de/8-Kanal-PCI-Videokar ... dZViewItem
This is just to inform you that it is working w/o problems with Linux/ZM.
The output of 'lspci' looks like this:
0000:02:00.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
0000:02:00.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
0000:02:01.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
0000:02:01.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
0000:02:02.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
0000:02:02.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
0000:02:03.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
0000:02:03.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
BTW: The Windows software shipped with the card freezes XP within minutes. You'll understand that i didn't spend much time in hunting bugs there ;)
PS: I forgot; the card is labeled as '408Y", so manufacturer seems to be 'Shenzhen Hawell Advanced Technology Co., Ltd.'.
This fits to the info given during the installation of the XP drivers.
Uli
zoneminder
Site Admin
Post by zoneminder »
Thanks for posting that. Hopefully it will help someone in the future.
Phil
crazymanbrad
Post by crazymanbrad »
I think I may have purchased a similar 4 cam card from ebay (except mine is from China) and it also came with hawell drivers.
It's nice to know that this card may work with zoneminder. I will leave an update once I've had a chance to try it.
Cheers,
Brad.
TimboUK
Post by TimboUK »
Sorry to be a nube (linux is all new, just used the live cd and got it running, ut no video in) I have 2 cheap ebay cards from chine. Can you please explain how to lspci ???
I assume this is from the pci card data?
Cheers
TimboUK
Post by TimboUK »
Ok, I read the FAQ !!
I got this info : (There are 2 similar cards in situ
[guest ~]$ lspci -v
00:00.0 Host bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133] (rev 03)
Flags: bus master, medium devsel, latency 8
Memory at d0000000 (32-bit, prefetchable)
Capabilities: <available only to root>
00:01.0 PCI bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133 AGP] (prog-if 00 [Normal decode])
Flags: bus master, 66Mhz, medium devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: d4000000-dbffffff
Prefetchable memory behind bridge: dc000000-e3ffffff
00:07.0 ISA bridge: VIA Technologies, Inc. VT82C686 [Apollo Super South] (rev 40)
Subsystem: VIA Technologies, Inc. VT82C686/A PCI to ISA Bridge
Flags: bus master, stepping, medium devsel, latency 0
00:07.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06) (prog-if 8a [Master SecP PriP])
Flags: bus master, medium devsel, latency 32
I/O ports at d000
00:07.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 1a) (prog-if 00 [UHCI])
Subsystem: VIA Technologies, Inc. (Wrong ID) USB Controller
Flags: bus master, medium devsel, latency 32, IRQ 11
I/O ports at d400
00:07.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 1a) (prog-if 00 [UHCI])
I/O ports at d800
00:07.4 Bridge: VIA Technologies, Inc. VT82C686 [Apollo Super ACPI] (rev 40)
Subsystem: VIA Technologies, Inc. VT82C686 [Apollo Super ACPI]
Flags: medium devsel, IRQ 11
00:07.5 Multimedia audio controller: VIA Technologies, Inc. VT82C686 AC97 Audio Controller (rev 50)
Subsystem: VIA Technologies, Inc. Onboard Audio on EP7KXA
Flags: medium devsel, IRQ 9
I/O ports at dc00
I/O ports at e000
I/O ports at e400
00:09.0 Multimedia video controller: JumpTec h, GMBH: Unknown device 6800 (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 5
Memory at e5000000 (32-bit, non-prefetchable)
00:0b.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RT8139
I/O ports at e800
Memory at 30000000 (32-bit, non-prefetchable)
00:0c.0 Multimedia video controller: JumpTec h, GMBH: Unknown device 6800 (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 10
Memory at e4000000 (32-bit, non-prefetchable) [size=16M]
01:00.0 VGA compatible controller: nVidia Corporation NV20 [GeForce3] (rev a3) (prog-if 00 [VGA])
Subsystem: Giga-byte Technology: Unknown device 3000
Flags: bus master, 66Mhz, medium devsel, latency 32, IRQ 10
Memory at d4000000 (32-bit, non-prefetchable) [size=16M]
Memory at dc000000 (32-bit, prefetchable) [size=64M]
Memory at e0000000 (32-bit, prefetchable) [size=512K]
Expansion ROM at e0080000 [disabled] [size=64K]
(The main chip says Techwell on it)
Is this a no go ?
Supra Dave
Post by Supra Dave »
I think it's best to go with the 8 channel 240/200 fps. Quite cheap on Ebay and almost working right out of the box (need to add a line in modprobe.conf)
This is the card, with the yellow connector;
http://www.jasonh.vispa.com/Card_Front.jpg
I hoped it was an universal PCI bus (3.3V/5V) card but it's not working in my 3.3V Linux file server! ( :cry: ) ... I put it in a "normal" pc now and it's working fine.
Thats the only negative thing I can find, but most of the multiple channel cards are 5V somehow.
Anamax
Post by Anamax »
What line did you add to modprobe, my card has the same chipset.
thanks
dave
kamand
Re: Cheap 4/8/16 port card on eBay
Post by kamand »
2tomcats wrote:Hi all,
Uli
Hi 2tomcats.
Can You share your modprobe.conf options for this card please?
I bought the same card too, but can use only first bttv chip.
Regards.
Andrew
PS:
Solved. card=77,77,77,77
Has 2 video input channels (0,1) for each(4) BT chip.
unclerichy
Post by unclerichy »
Supra Dave wrote:I think it's best to go with the 8 channel 240/200 fps. Quite cheap on Ebay and almost working right out of the box (need to add a line in modprobe.conf)
I've been looking at upgrading my current system to something beefier and have seen exactly the same card as in your photo. Are you finding it reliable?
Cheers.
