unable to generate Video files
cvsvs
Post by cvsvs »
I am running Zone Minder 1.21.4 and am unable to generate Videos. log (zmvideo.log) says:
Creating video file Event-1731-r1-s1.mpg for event 1731
/usr/bin/ffmpeg -y -r 4.14 -i %04d-capture.jpg -s 320x240 -r 25 Event-1731-r1-
Input #0, image, from '%04d-capture.jpg':
Duration: 00:10:02.8, bitrate: N/A
Stream #0.0: Video: rawvideo, yuvj444p, 320x240, 4.14 fps
Output #0, mpeg, to 'Event-1731-r1-s1.mpg':
Stream #0.0: Video: mpeg1video, 320x240, 25.00 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
sh: line 1: 29424 Segmentation fault /usr/bin/ffmpeg -y -r 4.14 -i %04d-cap
>ffmpeg.log
Any thoughts please!
Rgds
cvsvs
Flash_
Post by Flash_ »
ffmpeg seems to be broken.
Can you uninstall, purge, and re-install ffmpeg?
jameswilson
Post by jameswilson »
i second that that looks like an ffmpeg prob not a zm prob
James Wilson
cvsvs
re-install ffmpeg
Post by cvsvs »
could you please give me the re-install procedure?
Flash_
Post by Flash_ »
For which distro?
jameswilson
I strongly recommend you use either ross's or coreys distros as these just work. Plus it will be asier to assist you
James Wilson
cvsvs
Post by cvsvs »
James,
Can I directly upgrade from 1.21.4 to 1.22.2 by RPM? I downloaded the RPM from the site you gave in your Aug 25 posting , which is http://www.jpwilson.eu/zm-1.22.2-9_20060mdk.i586.rpm
(I am not a Linux expert; but can manage basic commands; would appreciate if you can give me any tips)
jameswilson
if your running ross's 2006 distro then yes
James Wilson
cvsvs
Unable to generate Video files.. ffmpeg corruption..
Post by cvsvs »
Ran the rpm ( from Ross's distro) and endedup with the following errors:
error: Failed dependencies:
perl-MIME-Lite is needed by zm-1.22.2-9_20060mdk.i586
apache2 is needed by zm-1.22.2-9_20060mdk.i586
libpcre is needed by zm-1.22.2-9_20060mdk.i586
liblame is needed by zm-1.22.2-9_20060mdk.i586
perl-X10 is needed by zm-1.22.2-9_20060mdk.i586
perl(X10::ActiveHome) is needed by zm-1.22.2-9_20060mdk.i586
perl-base >= 5.8.7 is needed by zm-1.22.2-9_20060mdk.i586
perl-base is needed by zm-1.22.2-9_20060mdk.i586
libavcodec.so.0 is needed by zm-1.22.2-9_20060mdk.i586
libavformat.so.0 is needed by zm-1.22.2-9_20060mdk.i586
libcrypto.so.0.9.7 is needed by zm-1.22.2-9_20060mdk.i586
libmysqlclient.so.14 is needed by zm-1.22.2-9_20060mdk.i586
cordel
Post by cordel »
Then you must not be using Ross's Distro. What Linux Distro did you load???
cvsvs
Post by cvsvs »
The distrobution is CTU3-zm1.21.3-3.
I wonder if "yum update" is all that I need to do to upgrade!!
cvsvs
Post by cvsvs »
Oooops! It appears that the yum update wont work past 1.24.1
I am back to square one.
Can any one assist me in fixing my ffmpeg issue? Basically I need the re-install procedure please!
jameswilson
see coreys site for a 1.22.2 rpm for ctu. You cant use ross's one as thats for mandrake.
But Corey has released a 1.22.2 rpm that you can use, but yum update wont do it as Corey doesnt have 1.22.2 as stable yet
James Wilson
cvsvs
Post by cvsvs »
Corey's site seems to be "under construction" ; could anyone give the URL?
jameswilson
James Wilson
