Integration with Heyu?
Posted: Wed Nov 19, 2003 12:21 pm
Hi
I like the possibility of using X10 to control ZM but at the moment I can't :( This is because I use Heyu to control X10. This does, however, provide a daemon which monitors the CM11A and dumps the results out to a file. It is suggested that applications that want to make use of the X10 data read the file rather than directly access the serial port.
Any chance ZM could be modded to access the file rather than the serial port?
