I would to create a security system not only with zoneminder and camera based on motion detect, but i would to start the record for a single camera
through an external sensor (temperature, motion, ecc) to have more
reliability, so my question is: what kind of hardware for sensors i have to use? how can i connect sensors to this hardware and than to pc? How can i control zoneminder after an external event?
External Sensor and Motion Detect
id be interested in this too! I have looked at various methods and the most widly used is to modify the parralel port but i would rather find a device that is ip or usb. So if you have any luick id like to know
James Wilson
I have a 4 cam system, but one of them is activated by PIR.
Under normal conditions the camera is turned off, so all you see in zoneminder is a blue screen, but if movement is detected by the pir power is connected to the camera (and a floodlight). This in turn triggers motion detection.
Only downside is that when the pir turns off power to the camera, you get another trigger for motion detection.
But this works reliably.
