Page 1 of 1
No Pictures
Posted: Thu Oct 26, 2006 3:23 pm
by gpalermo
I have ”ZM4MS 2.81 Beta” up and running on Windows XP, setup MYSQL access works I see all events “zm 1.22.2” my problem is I can’t see any pictures in playback or live I do see FPS coming across. It works when I put in a camera address. The paths are correct. Is their something missing?
Posted: Thu Oct 26, 2006 4:43 pm
by jameswilson
when you say it works when you put in a camera address do you mean url? and then turn on url mode? or something else
Posted: Thu Oct 26, 2006 4:58 pm
by gpalermo
yes - when i put in ulr and turn on ulr mode
Posted: Thu Oct 26, 2006 5:38 pm
by jameswilson
the default path is for the 2006 live cd only if your using another distro or your apache is setup differently it will fail. Is you box public?
Posted: Thu Oct 26, 2006 5:44 pm
by gpalermo
No it's not pubilc but I can make it public if you want to take a look.
Posted: Thu Oct 26, 2006 5:47 pm
by jameswilson
if you make your zm server and pm the details i will send you a correct path statement for zm4ms
Posted: Thu Oct 26, 2006 5:59 pm
by gpalermo
its public
http://167.206.149.3
default user and pass
Posted: Thu Oct 26, 2006 6:36 pm
by gpalermo
This is the public server
https://weld.dynalias.com/index.php
viewer
viewer
Posted: Thu Oct 26, 2006 8:10 pm
by jameswilson
i cant get the https path to work with zm as the cert is not from a trusted authority. Do you have a non https ie http available for me to test against
Posted: Fri Oct 27, 2006 12:26 pm
by gpalermo
https://skyeye.dynalias.com/
I created a certificate on this host you can install.
Posted: Fri Oct 27, 2006 3:07 pm
by jameswilson
Well i have set camera 36 up in the folloeing way usint the default path
ip = skyeye.dynalias.com
port = blank or :80 (you must include the ':' )
mon = 1
under paths
path = /cgi-bin/nph-zms
data type = https:// (changed from http://)
I also installed the cert and all is fine.
Posted: Fri Oct 27, 2006 5:24 pm
by gpalermo
It works - real nice.
Posted: Fri Oct 27, 2006 6:43 pm
by jameswilson
lol, finally!
