No picture with IP cameras
amerdsp
Post by amerdsp »
I had to resinstall my fedora core on a different hard disk and I just finished installing Zoneminder. However, there is no picture coming from my Axis 207 cameras although when i access it directly all is working fine.
The zmwatch.log gives me errors similar to the following and I do not understand why it is happening:
==> zmwatch.log <==
10/28/06 13:07:41.631854 zmwatch[8326].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
10/28/06 13:07:41.632155 zmwatch[8326].INF [Restarting capture daemon for Register, shared memory not valid]
10/28/06 13:07:41.819260 zmwatch[8326].INF ['zmc -m 1' started at 06/10/28 13:07:41] at /usr/local/bin/zmwatch.pl line 118
Has anyone encountered this before? Any ideas?
Thanks in advance,
A
jameswilson
Post by jameswilson »
are you using the correct path etc? and have you tried reg exp etc
James Wilson
cordel
Post by cordel »
Can you post what your settings are for that camera?
zmu -m1 -q
Regards,
Corey
