No events recording on Gentoo ZM install
Posted: Mon Nov 06, 2006 2:59 pm
Everything else seems to be working fine- ( see http://video.parknticket.com ). Zoneminder apparently logs into the mysql server with no problem, accesses the video devices as it should, and will stream jpeg images properly. I have a 128GB disk mounted under "events", and have even chmod'ed the folder "666" to make sure that it's writeable and readable to zonemindner.
I *do* get a couple of little red exclamation points instead of the green asterisk when zoneminder starts, but I can't see anything in particular in the logs, to wit:
video tmp # tail zmaudit.log
11/05/06 22:17:31.616767 zmaudit[6387].DBG [Found database monitor '12']
11/05/06 22:17:31.617464 zmaudit[6387].DBG [Got 2 events]
11/05/06 22:17:31.617598 zmaudit[6387].DBG [Found database monitor '13']
11/05/06 22:17:31.618242 zmaudit[6387].DBG [Got 2 events]
11/05/06 22:17:31.618375 zmaudit[6387].DBG [Found database monitor '14']
11/05/06 22:17:31.619014 zmaudit[6387].DBG [Got 2 events]
11/05/06 22:17:31.619144 zmaudit[6387].DBG [Found database monitor '15']
11/05/06 22:17:31.623381 zmaudit[6387].DBG [Got 92 events]
11/05/06 22:17:31.623542 zmaudit[6387].DBG [Found database monitor '16']
11/05/06 22:17:31.627131 zmaudit[6387].DBG [Got 92 events]
video tmp # tail zmdc.log
11/05/06 14:32:28.502297 zmdc[6323].INF ['zma -m 15' starting at 06/11/05 14:32:28, pid = 6370]
11/05/06 14:32:28.735186 zmdc[6323].INF ['zmc -d /dev/video3' already running at 06/11/05 14:32:28, pid = 6366]
11/05/06 14:32:28.936212 zmdc[6376].INF ['zma -m 16' started at 06/11/05 14:32:28]
11/05/06 14:32:28.942299 zmdc[6323].INF ['zma -m 16' starting at 06/11/05 14:32:28, pid = 6376]
11/05/06 14:32:29.171561 zmdc[6380].INF ['zmfilter.pl' started at 06/11/05 14:32:29]
11/05/06 14:32:29.172323 zmdc[6323].INF ['zmfilter.pl' starting at 06/11/05 14:32:29, pid = 6380]
11/05/06 14:32:29.772637 zmdc[6323].INF ['zmaudit.pl -c' starting at 06/11/05 14:32:29, pid = 6387]
11/05/06 14:32:29.773780 zmdc[6387].INF ['zmaudit.pl -c' started at 06/11/05 14:32:29]
11/05/06 14:32:30.205453 zmdc[6392].INF ['zmwatch.pl' started at 06/11/05 14:32:30]
11/05/06 14:32:30.212277 zmdc[6323].INF ['zmwatch.pl' starting at 06/11/05 14:32:30, pid = 6392]
video tmp # tail zmfilter.log
11/05/06 06:56:15.785329 zmfilter[10111].INF [Scanning for events]
11/05/06 07:14:16.478330 zmfilter[12280].INF [Scanning for events]
11/05/06 14:32:29.613032 zmfilter[6380].INF [Scanning for events]
video tmp # tail zmpkg.log
11/05/06 06:56:08.196611 zmpkg[10003].INF [Command: start]
11/05/06 07:11:05.771659 zmpkg[11928].INF [Command: start]
11/05/06 07:11:05.964329 zmpkg[11928].ERR [Unable to find valid 'su' syntax]
11/05/06 07:14:04.498603 zmpkg[12069].INF [Command: start]
11/05/06 09:36:08.308621 zmpkg[31443].INF [Command: start]
11/05/06 09:36:08.333331 zmpkg[31443].ERR [Unable to find valid 'su' syntax]
11/05/06 09:49:56.242565 zmpkg[24644].INF [Command: start]
11/05/06 09:53:39.549604 zmpkg[24749].INF [Command: start]
11/05/06 14:32:12.888846 zmpkg[6260].INF [Command: restart]
11/05/06 20:37:59.457002 zmpkg[28060].INF [Command: start]
video tmp # tail zmwatch.log
11/05/06 07:25:11.776630 zmwatch[12296].INF [Restarting capture daemon for one, shared memory not valid]
11/05/06 07:25:12.000451 zmwatch[12296].INF ['zmc -d /dev/video0' started at 06/11/05 07:25:11] at /usr/bin/zmwatch.pl line 118
11/05/06 07:25:12.001871 zmwatch[12296].INF [Restarting capture daemon for two, shared memory not valid]
11/05/06 07:25:12.263252 zmwatch[12296].INF ['zmc -d /dev/video0' started at 06/11/05 07:25:12] at /usr/bin/zmwatch.pl line 118
11/05/06 07:25:12.264726 zmwatch[12296].INF [Restarting capture daemon for three, shared memory not valid]
11/05/06 07:25:12.486033 zmwatch[12296].INF ['zmc -d /dev/video0' started at 06/11/05 07:25:12] at /usr/bin/zmwatch.pl line 118
11/05/06 07:25:12.487485 zmwatch[12296].INF [Restarting capture daemon for four, shared memory not valid]
11/05/06 07:25:12.708697 zmwatch[12296].INF ['zmc -d /dev/video0' started at 06/11/05 07:25:12] at /usr/bin/zmwatch.pl line 118
11/05/06 14:32:30.389857 zmwatch[6392].INF [Watchdog starting]
11/05/06 14:32:30.390512 zmwatch[6392].INF [Watchdog pausing for 30 seconds]
Zoneminder version: 1.22.2
mysql version info:
mysqladmin Ver 8.41 Distrib 5.0.26, for pc-linux-gnu on i686
Copyright (C) 2000 MySQL AB & MySQL Finland AB & TCX DataKonsult AB
This software comes with ABSOLUTELY NO WARRANTY. This is free software,
and you are welcome to modify and redistribute it under the GPL license
Server version 5.0.26-log
Protocol version 10
Connection Localhost via UNIX socket
UNIX socket /var/run/mysqld/mysqld.sock
Uptime: 15 hours 22 min 28 sec
Threads: 19 Questions: 138599 Slow queries: 0 Opens: 24 Flush tables: 1 Open tables: 18 Queries per second avg: 2.504
OS/system:
Linux video 2.6.17-gentoo-r8 #1 SMP Wed Nov 1 21:15:13 EST 2006 i686 Intel(R) Pentium(R) 4 CPU 2.40GHz GenuineIntel GNU/Linux
I'm also curious about the "shared memory not valid" entry above in the zmwatch.log file. Could this have anything to do with my problem?
Thanks to anyone who might be able to help, in advance...
mysql version info:
Protocol version 10
OS/system:
