Hi.
Soon ive got one of thes camra in reach for testing with zm, is it known to work?
IQeye700 Network Cameras
i tested one but failed but it is beleived to work yes
James Wilson
Hi finaly ive got the cam,
ive got it to work in the network, browsing the camera in the new with http://ip/now.jpg works prefect, i just cant get ZM to grab the pic.
my settings are
Monitor Iqeye
Type : Remote
Host : 192.168.1.200
Port : 80
Path : /now.jpg
Width : 512
Height : 384
Thats what i change, should i change someting more?
Zm is 1.22.2
my settings are
Monitor Iqeye
Type : Remote
Port : 80
Path : /now.jpg
Width : 512
Height : 384
Zm is 1.22.2
id try 1.22.3 as this is better with ip cameras
James Wilson
you will probably run into a shared mem linit on the higher res's if so check you logs to confirm
James Wilson
it works like a charm now..
Calibrating delay using timer specific routine.. 4810.35 BogoMIPS (lpj=9620710)
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
AMD Athlon(tm) 64 X2 Dual Core Processor 4600+ stepping 02
using 3 segate Model: ST3250624AS in a software raid.
mobo is Asus M2NPV-vm bord with 2gb ram on.
and gfx is MSI NX7300GS
Dist is http://cdimage.debian.org/cdimage/etch_ ... etinst.iso
just installed zm bye the installations instuctions , had wrong password but after fixing that it works lika hell..
now i want to use the zm to just take stills at alarm, and show it on a LCD like 50" or so..
