Page 1 of 1
AXIS 231D+. Dome Camera (PTZ)
Posted: Tue Nov 21, 2006 7:55 am
by jlnavio
Hello, friends!!
Has somebody used Axis Dome Camera 231D+ with ZM??
Is it compatible with ZM??
I have one. It resolutions are:
4CIF (704x576)
2CIF Expanded (704x576)
2CIF (704x288)
CIF (352x288)
QCIF (176x144)
Does somebody know these resolutions CIF??
Thanks.
Posted: Tue Nov 21, 2006 8:11 am
by cordel
[Moved to the correct topic]
Yes this camera should have no problems working with ZM.
Regards,
Corey
Posted: Tue Nov 21, 2006 10:42 am
by memone
Hi, I use a 214PTZ, but I think it's quite the same.
It is fully functional with zm at 4CIF and CIF resolutions and the PTZ controls are working very well..
Regards
Vincenzo
Posted: Tue Nov 21, 2006 12:10 pm
by jlnavio
Ok, thanks.
It have already run, but only with resolution = 352x288
I put into "Device Path": /axis-cgi/mjpg/video.cgi?resolution=352x288
and "Capture Width (pixels)"-->352, "Capture Heigth (pixels)"-->288
How can I use 4CIF (704x576)??
Posted: Tue Nov 21, 2006 12:23 pm
by memone
Ok, thanks.
Oh, sorry for not reading well.. in the setup menu of my 214 there are these resolutions (maybe an NTSC/PAL version difference?):
CIF: 384x288
4CIF: 768x576
I've got "/axis-cgi/mjpg/video.cgi" only in Remote Host Path and then I set the resolution via the Capture Height and Width fields
I just select 4CIF in the setup menu of my cam and change width and height in zm accordingly. Be aware that such a high resolution will use much CPU power and maybe you have to increase the shmmax and shmall values.
Regards
Posted: Tue Nov 21, 2006 12:37 pm
by jlnavio
Sorry, memone, I wanted to say "Remote Host Path".
OK, in the setup menu of my 231D+ there are also the same resolutions; but when i put these ones (704x576, i.e.) into Width and Heigth fields, ZM don't show the scene. Only with 352x288 it runs.
I put this line into /etc/sysctl.conf file: "kernel.shmmax=134217728", but I didn't put anythig like "shmall".
have I to add this optioin?? Is my setting of shmmax sufficient??
Posted: Tue Nov 21, 2006 2:45 pm
by memone
I've checked for that resolution thing.. the difference is in checking or not the flag "aspect ratio correction" in the setup menu: anyway for me it's working at both res (704x576 and 720x576).
For shmall is adviced (look at FAQ) to set the same value you put for shmmax.
For your problem I think you have to have a look at log messages (in my system they are in the /tmp/ folder), at first in zmdc.log.
Try also in the config panel, in the debug tab, to enable extra logging an to increase the debug level.
Vincenzo
PTZ on 214
Posted: Sat Apr 14, 2007 7:10 am
by herf
I use ZM 1.22.1 on Debian with 214 ptz and it works fine for the visualisation in (/axis-cgi/jpg/image.cgi?resolution=768x576), but I can't activate the ptz function.
I choose the option ptz in "Options/System".
I choose Axis API V2 in the control settings of the camera, but I don't really what to put in Control Device and Control Address.
Thanks for your help.
Posted: Thu Jan 20, 2011 11:51 pm
by ediaz
Hi thanks for the idea..
READ de API of axix there is many good documentation..
put control type Axis
Control address: useroperator:pass@192.168.1.203
rest null
