Q: How can i change date/time format whit my country standard?
R: Is too easy! You must only change some line of the code of your zm_config.php file.
The line to do change are:
#68
define( "DATE_FMT_CONSOLE_LONG", "D jS M, g:ia" ); // This is the main console date/time, date() or strftime() format
define( "STRF_FMT_DATETIME_SHORT", "%y/%m/%d %H:%M:%S" ); // Strftime shorter format for dates with time, not locale aware
define( "STRF_FMT_DATETIME_SHORTER", "%m/%d %H:%M:%S" ); // Strftime shorter format for dates with time, not locale aware, used where space is tight
You must simply change the format of the date following the php format's date table. http://it2.php.net/date
Example:
Change the line 77 with this
define( "STRF_FMT_DATETIME_SHORT", "%d/%m/%Y %H:%M:%S" );
The result is: 24/11/20006 18:33:40
Best Regards.
Ettore.
________
C77
