I have 2 cams currently connected http://www.ptast.com/media/
One cam (Front) is captured OK but the second one (Backyard) is out of synch.
Here's how it should look (in the dark)
And here how it is now
11/29/06 00:16:19.128505 zmc_dvideo[4042].DB1-zm_monitor.cpp/329 [Monitor Backyard-IR has function 2]
11/29/06 00:16:19.128570 zmc_dvideo[4042].DB1-zm_monitor.cpp/330 [Monitor Backyard-IR LBF = '%y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
11/29/06 00:16:19.128614 zmc_dvideo[4042].DB1-zm_monitor.cpp/331 [Monitor Backyard-IR IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 1, FM = 0]
11/29/06 00:16:19.129599 zmc_dvideo[4042].DB1-zm_zone.cpp/849 [Got 0 zones for monitor Backyard-IR]
11/29/06 00:16:19.129708 zmc_dvideo[4042].DB1-zm_monitor.cpp/1619 [Loaded monitor 1(Backyard-IR), 0 zones]
11/29/06 00:16:19.129751 zmc_dvideo[4042].INF-zmc.cpp/183 [Starting Capture]
11/29/06 00:16:57.151480 zmc_dvideo[4042].INF-zm_signal.cpp/54 [Got signal (Terminated), exiting]
11/29/06 00:16:57.151900 zmc_dvideo[4042].ERR-zm_local_camera.cpp/615 [Sync failure for frame 5 buffer 5(1): Interrupted system call]
You can view my setting at http://213.250.83.82/zm/
username: guest
password: zmguest
