Avail RPM's
liderbugzm
Avail RPM's
Post by liderbugzm »
The download page lists a site - www.computerntelecom.com - where someone has hosted ?several? rpm packages. However it seem to not be there [ the site ]. No html, no ping. :(
Is there anyplace / anyone else that has rpm's? Spec. FC-4
jameswilson
Post by jameswilson »
corey is that site, will need him to pop in.
corey if your having issues i can set u up a virtual server on one of ip's and give you access. just let me know
James Wilson
cordel
Post by cordel »
Yeah the network got knocked out where the server was colocated and is off line from a recent storm :(
I just picked it up and purchaced a hosting service to move the site to and am in the process of migrating everything over to it. Should be done in a few days.
Regards,
Corey
mc
Post by mc »
Any news on this new yum update site yet? Trying to upgrade my fc3 to fc5 or fc6 - but cannot find baseurl report comes up.
Many thanks
MC
jameswilson
you wont be able to yum update to a newer fedora core, or at least i dont think you can
James Wilson
mc
Post by mc »
oh b*gger :cry:
Is there any way I can remove zoneminder and upgrade to fc6, then reload it?
jameswilson
there are people on here that have done mini how toos using fc6 and zm, but i dont think corey has rpms for fc6 yet. I thought moveing to a new 'core' meant trashing hd and starting again. If not and you can upgrade give it a go and let us know
James Wilson
mc
Post by mc »
Yum update works normally on Fedora, it's just the added programs that aren't a part of the standard fedora package that seem to cause me problems. Zoneminder would work with this if only the link to the RPM's site was working (I think)!
mira
Post by mira »
I am also very interested about the centos rpm packages. It would be very helpful !
