upgrading from 1.22.2 to 1.22.3
ttsoares
Post by ttsoares »
Slackware 11.0.
Compilation was fine, no warning or errors.
No need of the ffmpeg patch...
Just the database upgrade shows something:
perl zmupdate.pl -version=1.22.2 --user=xxxx --pass=xxxxx
Bareword found in conditional at zmupdate.pl line 149.
Update agent starting at 06/12/07 15:09:20
Initiating database upgrade to version 1.22.3
Please ensure that ZoneMinder is stopped on your system prior to upgrading the database.
Press enter to continue or ctrl-C to stop :
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file if you have a lot of events.
Press 'y' for a backup or 'n' to continue : n
Upgrading database to version 1.22.3
Database successfully upgraded from version 1.22.2.
Loading config from DB
DBI::db=HASH(0x86c38e0)->disconnect invalidates 1 active statement handle (either destroy statement handles or call finish on them before disconnecting) at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/ConfigAdmin.pm line 1657, <STDIN> line 2.
Saving config to DB
Database upgrade to version 1.22.3 successful.
Update agent exiting at 06/12/07 15:09:38
Is this normal ?
The fact is a secondary aspect of Reality.
cordel
Post by cordel »
The first error is because a new value is introduced to the database that don't exist until after you upgrade it -> This is probably Okay
The Second error I'm not sure.
Regards,
Corey
zoneminder
Site Admin
Post by zoneminder »
The second error should not be there but does not indicate a problem. It just implies that the script did not explicitly indicate that it had finished a particular statement before disconnecting. I have now corrected that anyway.
If zmupdate says it was successfful then it usually means that it was, fortunately :lol:
Phil
