Page 1 of 1
anybody have a clue
Posted: Mon Dec 18, 2006 9:20 am
by ma77hias
I am running ZM 1.22.3 on RHES 3 with a DLink 900
when I do modect I get this
12/18/06 07:45:18.518572 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:45:18, pid = 392]
12/18/06 07:46:02.609342 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:46:02]
12/18/06 07:46:08.790900 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:46:46.238654 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:46:46, pid = 510]
12/18/06 07:47:24.876825 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:47:24]
12/18/06 07:47:31.612049 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:48:02.437606 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:48:02, pid = 639]
12/18/06 07:48:45.922498 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:48:45]
12/18/06 07:48:52.906285 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:49:25.887046 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:49:25, pid = 724]
12/18/06 07:49:59.018739 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:49:59]
12/18/06 07:50:05.287433 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:50:45.636483 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:50:45, pid = 811]
12/18/06 07:51:27.754095 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:51:27]
12/18/06 07:51:34.508887 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:52:07.345528 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:52:07, pid = 912]
12/18/06 07:52:47.127649 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:52:47]
12/18/06 07:52:53.813824 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:53:27.814937 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:53:27, pid = 1063]
12/18/06 07:54:07.851329 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:54:07]
12/18/06 07:54:14.236590 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:54:43.223636 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:54:43, pid = 1118]
12/18/06 07:55:20.284452 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:55:20]
12/18/06 07:55:27.251076 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:56:05.771447 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:56:05, pid = 1224]
12/18/06 07:56:45.238379 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:56:45]
12/18/06 07:56:51.436570 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:57:24.232105 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:57:24, pid = 1321]
12/18/06 07:58:00.976443 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:58:00]
12/18/06 07:58:07.834335 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:58:38.570646 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:58:38, pid = 1458]
12/18/06 07:59:11.760307 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 07:59:11]
12/18/06 07:59:17.954270 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
12/18/06 07:59:42.318010 zmdc[932].INF ['zmc -m 1' starting at 06/12/18 07:59:42, pid = 1512]
12/18/06 08:00:21.435857 zmdc[932].INF ['zmc -m 1' stopping at 06/12/18 08:00:21]
12/18/06 08:00:28.268072 zmdc[932].INF ['zmc -m 1' crashed, signal 8]
ANybody have a clue what signal 8 is, and what I am doing wrong ?
I am using regular expression matching and http 1.1
Posted: Wed Dec 20, 2006 2:02 pm
by zoneminder
Signal 8 is Floting Point Exception. You normally should get a backtrace when this happens, possibly in /var/log/messages? That should give more info, but my initial suspicion would be to check your zones and make sure that they are all in range of the image dimensions etc.
Thanks for the reply
Posted: Wed Dec 20, 2006 2:24 pm
by ma77hias
Thanks for the suggestion, I redefined the Zones so they are not right at the border of the frame.
Have to monitor the system for some days to see if it solves my problem.
Posted: Thu Dec 21, 2006 10:45 am
by zoneminder
Right on the border should be fine, and it should not let you exceed it from now on. However in a previous upgrade, some rounding errors during the migration caused some zones to be one pixel out, which then caused random errors for some people.
Posted: Thu Dec 21, 2006 12:59 pm
by ma77hias
Ok helped to remove the signal 8 errors, but I am still getting this
12/21/06 03:47:59.366288 zmdc[3405].ERR ['zmc -m 1' exited abnormally, exit status 255]
a couple of times during the night when I am using modect.
Is this normal ?
I have switched on full debug, but i don't get any errors.
Besides the occasional exit status 255, everything works fine.
Thanks for a great product!!
Merry Christmas
Posted: Sun Dec 24, 2006 3:23 pm
by zoneminder
I am putting some more debug in at every exit point to trap these kind of intermittent issues, as at the moment I think it can be a bit tricky to track down.
