Page 1 of 1
Broken image
Posted: Fri Dec 22, 2006 1:41 am
by mikesjays
I first thought I had a driver problem but I can get images from my cam useing tvtime. When I pull up the moniter window in ZM i get a broken image icon and I have no idea where to start. This is the first time I have tried something complex like this. I followed the FC6 Wiki but nothing. Where should I look first?
OS fedora6
Card Pv 153
Posted: Fri Dec 22, 2006 1:53 am
by cordel
Check the trouble shooting sections of the README and the FAQ.
Posted: Fri Dec 22, 2006 2:26 am
by mikesjays
Here is an error I'm getting in my system log
Dec 21 21:41:38 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 21 21:43:07 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
Dec 21 21:43:07 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/21 21:43:07, pid = 3832]
Dec 21 21:43:07 vserver zmdc[3832]: INF ['zmc -d /dev/video0' started at 06/12/21 21:43:07]
Dec 21 21:43:07 vserver zmc_dvideo0[3832]: INF [Debug Level = 0, Debug Log = <none>]
Dec 21 21:43:07 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Posted: Fri Dec 22, 2006 11:19 pm
by cordel
mikesjays wrote: Dec 21 21:41:38 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
This suggests that zm is not able to capture an image from the device and confirms your problem.
Have you turned up the debug?
Are there no other errors in any of the other logs?
Posted: Sat Dec 23, 2006 2:15 am
by mikesjays
here are the results of dmesg | grep -4 bttv
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
audit(1166734441.840:2): selinux=0 auid=4294967295
Linux video capture interface: v2.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:02:08.0[A] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
bttv0: Bt878 (rev 17) at 0000:02:08.0, irq: 10, latency: 64, mmio: 0xf69f8000
bttv0: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv0: using: ProVideo PV150 [card=98,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (1).
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:02:09.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
bttv1: Bt878 (rev 17) at 0000:02:09.0, irq: 11, latency: 64, mmio: 0xf69fa000
bttv1: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv1: using: ProVideo PV150 [card=98,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
PCI: setting IRQ 9 as level-triggered
ACPI: PCI Interrupt 0000:02:0a.0[A] -> Link [LNKB] -> GSI 9 (level, low) -> IRQ 9
bttv2: Bt878 (rev 17) at 0000:02:0a.0, irq: 9, latency: 64, mmio: 0xf69fc000
bttv2: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv2: using: ProVideo PV150 [card=98,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .<6>i810_smbus 0000:00:01.0: i810/i815 i2c device found.
. ok
bttv: Bt8xx card found (3).
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
ACPI: PCI Interrupt 0000:02:0b.0[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
bttv3: Bt878 (rev 17) at 0000:02:0b.0, irq: 11, latency: 64, mmio: 0xf69fe000
bttv3: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv3: using: ProVideo PV150 [card=98,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
ACPI: PCI Interrupt 0000:02:08.1[A] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
bt878_probe: card id=[0x1460aa00], Unknown card.
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
Bluetooth: HIDP (Human Interface Emulation) ver 1.1
eth0: no IPv6 routers present
bttv0: PLL can sleep, using XTAL (28636363).
Posted: Sat Dec 23, 2006 3:52 am
by cordel
Okay, that shows that the devices are initialized and we already know they work since you have them working with tvtime, but yields no errors as I requested.
Try using:
tail -f /tmp/zm*.log /var/log/messages
adjust the paths as required and start zm to see what transpires.
You might need to turn up the debug and check the debug logs.
Posted: Sat Dec 23, 2006 1:55 pm
by mikesjays
==> /tmp/zmaudit.log <==
12/23/2006 07:55:09.735378 zmaudit[2243].DBG [Found filesystem monitor '1']
12/23/2006 07:55:09.735936 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:10:09.745927 zmaudit[2243].DBG [Found database monitor '1']
12/23/2006 08:10:09.747893 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:10:09.749082 zmaudit[2243].DBG [Found filesystem monitor '1']
12/23/2006 08:10:09.749858 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:25:09.771931 zmaudit[2243].DBG [Found database monitor '1']
12/23/2006 08:25:09.773903 zmaudit[2243].DBG [Got 0 events]
12/23/2006 08:25:09.775062 zmaudit[2243].DBG [Found filesystem monitor '1']
12/23/2006 08:25:09.775838 zmaudit[2243].DBG [Got 0 events]
==> /tmp/zmdc.log <==
12/23/2006 08:37:14.154303 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:14, pid = 25575]
12/23/2006 08:37:14.227949 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:24.994152 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:24, pid = 25579]
12/23/2006 08:37:25.057644 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:35.849854 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:35, pid = 25600]
12/23/2006 08:37:35.916751 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:46.669718 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:46, pid = 25605]
12/23/2006 08:37:46.730660 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:37:57.518058 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
12/23/2006 08:37:57.587457 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
==> /tmp/zmfilter.log <==
12/23/2006 08:29:23.225555 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:30:23.228448 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:31:23.231278 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:32:23.506008 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:33:23.521126 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:34:23.527785 zmfilter[2237].DBG [Reloading filters]
12/23/2006 08:34:23.545681 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:35:23.550540 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:36:23.554269 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:37:23.560978 zmfilter[2237].DBG [Sleeping for 60 seconds]
==> /tmp/zmpkg.log <==
12/20/2006 22:26:11.540006 zmpkg[9884].INF [Command: start]
12/20/2006 23:23:54.255445 zmpkg[24881].INF [Command: stop]
12/21/2006 06:31:42.253730 zmpkg[2191].INF [Command: start]
12/21/2006 17:18:43.641774 zmpkg[31516].INF [Command: stop]
12/21/2006 17:25:41.011687 zmpkg[2159].INF [Command: start]
12/21/2006 17:55:07.963532 zmpkg[2178].INF [Command: start]
12/21/2006 20:46:32.587884 zmpkg[8938].INF [Command: stop]
12/21/2006 20:54:54.065436 zmpkg[2158].INF [Command: start]
==> /tmp/zmupdate.log <==
12/20/2006 22:26:23.909780 zmupdate[9935].INF [Checking for updates]
12/20/2006 22:26:24.627371 zmupdate[9935].INF [Got version: '1.22.3']
12/21/2006 22:55:13.319698 zmupdate[2258].INF [Checking for updates]
12/21/2006 22:55:15.507297 zmupdate[2258].INF [Got version: '1.22.3']
12/22/2006 22:55:15.728641 zmupdate[2258].INF [Checking for updates]
12/22/2006 22:55:16.099971 zmupdate[2258].INF [Got version: '1.22.3']
==> /tmp/zmwatch.log <==
12/23/2006 08:37:25.077770 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:24, pid = 25579]
12/23/2006 08:37:35.086887 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:37:35.088259 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:37:35.878994 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:35, pid = 25600]
12/23/2006 08:37:45.890195 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:37:45.891559 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:37:46.745207 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:46, pid = 25605]
12/23/2006 08:37:56.753818 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:37:56.755122 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:37:57.609085 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
==> /var/log/messages <==
Dec 23 08:37:46 vserver zmc_dvideo0[25605]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:37:46 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:37:46 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:46, pid = 25605]
Dec 23 08:37:56 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:37:56 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:37:57 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
Dec 23 08:37:57 vserver zmdc[25609]: INF ['zmc -d /dev/video0' started at 06/12/23 08:37:57]
Dec 23 08:37:57 vserver zmc_dvideo0[25609]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:37:57 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:37:57 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:37:57, pid = 25609]
12/23/2006 08:38:07.621647 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:07.622939 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:07 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:07 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:08.465332 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
12/23/2006 08:38:08.545150 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:08.515263 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
Dec 23 08:38:08 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
Dec 23 08:38:08 vserver zmdc[25615]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:08]
Dec 23 08:38:08 vserver zmc_dvideo0[25615]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:08 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:08, pid = 25615]
Dec 23 08:38:08 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:18.528817 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:18.530114 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:18 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:18 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:19.364992 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
12/23/2006 08:38:19.442373 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:19.415761 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
Dec 23 08:38:19 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
Dec 23 08:38:19 vserver zmdc[25619]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:19]
Dec 23 08:38:19 vserver zmc_dvideo0[25619]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:19 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:19, pid = 25619]
Dec 23 08:38:19 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:23.567097 zmfilter[2237].DBG [Sleeping for 60 seconds]
12/23/2006 08:38:29.438879 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:29.440171 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:29 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:29 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:30.296498 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
12/23/2006 08:38:30.364321 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:30.377960 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
Dec 23 08:38:30 vserver zmdc[25623]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:30]
Dec 23 08:38:30 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
Dec 23 08:38:30 vserver zmc_dvideo0[25623]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:30 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:38:30 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:30, pid = 25623]
12/23/2006 08:38:40.384970 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:40.386284 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:40 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:40 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:41.216699 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
12/23/2006 08:38:41.280530 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:41.297907 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
Dec 23 08:38:41 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
Dec 23 08:38:41 vserver zmdc[25627]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:41]
Dec 23 08:38:41 vserver zmc_dvideo0[25627]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:41 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Dec 23 08:38:41 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:41, pid = 25627]
12/23/2006 08:38:51.309225 zmwatch[2253].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
12/23/2006 08:38:51.310576 zmwatch[2253].INF [Restarting capture daemon for rich, shared memory not valid]
Dec 23 08:38:51 vserver zmwatch[2253]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Dec 23 08:38:51 vserver zmwatch[2253]: INF [Restarting capture daemon for rich, shared memory not valid]
12/23/2006 08:38:52.220322 zmdc[2178].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
12/23/2006 08:38:52.373237 zmdc[2178].INF ['zmc -d /dev/video0' crashed, signal 4]
12/23/2006 08:38:52.250589 zmwatch[2253].INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
Dec 23 08:38:52 vserver zmdc[25631]: INF ['zmc -d /dev/video0' started at 06/12/23 08:38:52]
Dec 23 08:38:52 vserver zmdc[2178]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
Dec 23 08:38:52 vserver zmwatch[2253]: INF ['zmc -d /dev/video0' starting at 06/12/23 08:38:52, pid = 25631]
Dec 23 08:38:52 vserver zmc_dvideo0[25631]: INF [Debug Level = 0, Debug Log = <none>]
Dec 23 08:38:52 vserver zmdc[2178]: INF ['zmc -d /dev/video0' crashed, signal 4]
Posted: Sun Dec 24, 2006 3:45 pm
by zoneminder
Signal 4, which is what zmc is crashing with, is an illegal instruction. Are you sure you have compiled ZM for the correct architecture?
Posted: Sun Dec 24, 2006 4:59 pm
by mikesjays
you know waht I might not have. how would one recompile and re install?
Posted: Sun Dec 24, 2006 5:47 pm
by zoneminder
JUst follow the instructions for building in the README and you should be ok.
Posted: Sun Dec 24, 2006 6:15 pm
by mikesjays
Ok that did the trick, thank you all for the help
Posted: Thu Jan 04, 2007 1:06 am
by hackeron
mikesjays wrote:Ok that did the trick, thank you all for the help
What exactly did you do? -- I followed the readme and am still getting:
04/01/07 01:06:02.434151 zmwatch[22999].INF ['zmc -d /dev/video' starting at 07/01/04 01:06:02, pid = 23173]
04/01/07 01:06:12.435894 zmwatch[22999].ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
04/01/07 01:06:12.436309 zmwatch[22999].INF [Restarting capture daemon for Philips, shared memory not valid]
Posted: Thu Jan 04, 2007 1:49 am
by jameswilson
it appears your using an saa based card. If i were you that doesnt look related to this thread start a new topic detailing as much info as you can ie card type logs etc
James
