ZoneMinder 10152006 (ViewMAX) ???
R2D2
Post by R2D2 »
I found this accidently:
But what the Hell is it, and why no one is talking about here in the Forum?
zoneminder
Site Admin
Post by zoneminder »
I think it has been mentioned. I think user Intelio just reskinned some of the pages slightly so it's still ZM under the hood. If you search for his posts you should find something.
Phil
R2D2
Post by R2D2 »
zoneminder wrote:I think it has been mentioned. I think user Intelio just reskinned some of the pages slightly so it's still ZM under the hood. If you search for his posts you should find something.
Sorry, but didn't find anything about....
Is ViewMAX only available as ISO Live-CD Image, our can i get this frondend for ZM as standalone application???
zoneminder
Site Admin
I have not used it but I would be surprised if it was an iso. You can get it by following the bracnhes link at http://freshmeat.net/projects/zoneminder/
Phil
R2D2
Post by R2D2 »
zoneminder wrote:I have not used it but I would be surprised if it was an iso. You can get it by following the bracnhes link at http://freshmeat.net/projects/zoneminder/
It's really an ISO, Look here
R2D2
Post by R2D2 »
Found this here
ViewMAX-10152006
Notes:
ViewMAX Deployment
Imaged System hardware:
SIS661 Chipset w/ Intel Celeron 2.53GHz LGA775 Processor, 1GB of System Memory, 3ware Drive Array chassis and 4 Port SATA RAID adapter, 3 SATA Seagate 200GB drives in a raid 5, 1 PATA Seagate 40GB drive for the system, ProVideo PV-155 16-port BT878a based CCTV capture card.
Built on Ubuntu LTS 6.06 Server AMD64/x86_64 Architecture (these images WILL NOT WORK ON NON x86_64 system!!!!!)
1. Create drive array in the 3ware BIOS. Configure as RAID5 utilizing all drives attached to the controller. Press F8.
2. Boot from System Rescue CD. Create the following parition scheme:
Partition Table
Device Mount Type FS Size
/dev/hda1 /boot Primary ext3 100MB
/dev/hda2 / Primary ext3 the rest
/dev/hda3 n/a Extended n/a 4GB
/dev/hda5 n/a Logical Swap 2GB
/dev/hda6 n/a Logical Swap 2GB
/dev/sda1 /opt/viewmax Primary XFS 100%
3. Use partimage to extract hda1.img and hda2.img to the appropriate partitions. Follow the instructions on screen, partimage is very straight forward. You will either need the images available locally or you will need them located on a PartImaged server on the network. I generally setup a PartImaged server on my laptop or use an external USB drive which contains the images. After the images are all done create a new file system on /dev/sda1, format to the XFS file system (note, due to the volume size and the constant write nature of the DVR XFS or JFS are required, do not try to use EXT3).
4. Reboot the system using an Ubuntu or other AMD64(x86_64) LiveCD (the x86_64/amd64 part is an absolute requirement otherwise chroot will not work). Boot to a command prompt and make sure you are root. If you end up on a desktop hit CTRL+BACKSPACE+F12 followed by ALT+F1. This will place you in tty1, login (as root) if required by the distribution, if you are automatically logged in then 'sudo su' to become root.
5. The following steps must be completed in EXACT ORDER, check your spelling carefully before execution of any commands, read this section through completely FIRST make sure you understand it, and then proceed. Everything between the ' should be typed exactly as presented! After the second ' you should press enter. The prompt is represent by # for BASH, and grub> for the grub shell. example: #'echo "I read the directions, because I am cool like that"'
a. #'mkdir /target'
b. #'mount /dev/hda2 /target'
c. #'mount /dev/hda1 /target/boot'
d. #'mount --bind /dev /target/dev'
e. #'mount --bind /proc /target/proc'
f. #'mount /dev/sda1 /target/opt/viewmax'
g. #'chroot /target'
You are now using the ViewMAX file system as your root environment, all commands executed here on out will potentially have a permanent effect on the installation.
h. #'cd /home/intelio/viewmax'
This should place you in /opt/viewmax unless the symlink is broken. You will need to copy the file opt_viewmax.tar.bz2 to this directory, I generally copy it over the network via FTP, HTTP or you can use a removeable disk.
i. #'tar xjfv opt_viewmax.tar.bz2 && rm opt_viewmax.tar.bz2'
You now have a complete ViewMAX installation, however we still need to make this new system's filesystem bootable. If you stop now the system will not be able to reboot.
j. #'grub'
You are now inside the GRUB shell... these are simple but important steps, this will write the grub boot configuration to the master boot record of the system hard drive.
k. grub>'root (hd0,0)'
l. grub>'setup (hd0)'
m. grub>'quit'
You are now back in your root BASH shell and the MBR is prepared for booting, simple eh? Just a couple more steps left.
n. #'rcconf'
In the dialog screen that pops up verify that ViewMAX, mysql, and apache are NOT set to start, if they appear at the bottom of the list with no * next them you are ok. If they are set to start highlight them and press the space key. Exit this utility when you are done.
o. #'vi /etc/fstab'
You will need to uncomment the fstab entry for /dev/sda1, save and exit this file. DO NOT CHANGE ANYTHING ELSE.
p. #'shutdown -h now'
6. The system goes down, you should see the ViewMAX shutdown screen at this point. Make sure to get you boot cd out of the system. After it's all powered off, power it back on and let it boot from the hard drive, you should get the ViewMAX startup screen and then a login prompt. Login as 'intelio' password is set to 'at3carwash' There is no root user password, root is not permited to login even locally. At this point you need to sudo su, copy the vpn keys for this specific system to /etc/openvpn and extract them, make sure they are in /etc/openvpn and not a subdirectory. Next check that /opt/viewmax contains files. If it does not then /dev/sda1 is likely not mounted, check fstab... You will need to run 'rcconf' again, and enable Apache, ViewMAX and MySQL. Reboot with "shutdown -r now" and when it comes up all should work. Stop right here and shut the system down. Do not make any further changes to the system, configuration of the cameras needs to happen onsite with the cameras attached, the system is preconfigured with 16 cameras, all disabled. Once onsite simply enabled the correct number of cameras. The default user/pass for the ViewMAX web interface is intelio/wa54max, the default administrator for the 3ware array utility is the same as the intelio ViewMAX password. You can hit the 3ware array interface ONLY once the dvr has established a vpn connection to the Intelio network by going to it's VPN address on port 888, example: http://172.16.0.XX:888
You can also reach the DVR via SSH on this address, the only service which is available through the sites public ip address is the ViewMAX Web interface, this is by design, port forwarding external traffic to the 3ware utility is highly ill advised.
It's still a rough outline, but if you follow the above to the letter you will end up with a working system (baring hardware failure).
intelio
Post by intelio »
R2D2 wrote:Is ViewMAX only available as ISO Live-CD Image, our can i get this frondend for ZM as standalone application???
It is not a live-cd, it was released as both partition images containing the complete system, and another release with just the "skin" which you can place on top of your own ZM install.
The October image release is HERE
The interface only release is
HERE
You can also link to the project via http://idvr.org
gola10
Post by gola10 »
Could the Viewmax Interface be installed in a computer that does not have Zoneminder to use it as a remote viewer of a zoneminder installation that is on a remote site?
intelio
Post by intelio »
it's feasible, i've split the zoneminder interface before to access 48 cameras installed to 12 seperate systems running the actual zm process. it's a huge pain in the a$$ to setup though and requires a few days of hacking and trial and error
R2D2
Post by R2D2 »
intelio wrote:The interface only release is
HERE
I've downloaded the file, but there is no redme or howto inside.
Unfortunately i don't kwow what i have to do with the files...
Can somebody help me please?
intelio
Post by intelio »
Referrence the Wiki http://www.zoneminder.com/wiki/index.php/ViewMAX
Also, you could bother reading replies to your own posts on this same subject.... http://www.zoneminder.com/forums/viewtopic.php?t=7426
