I've been away from ZoneMinder for a couple of releases due to pressure of other work - but I've found time to carry on the good works!
I've sucessfully installed 0.9.16 on a Slackware 9.1 box using an IVG-200 card. (detailed notes on how to do this are available - perhaps Phil would like to post them?). I've also been loaned a DLink DCS-1000 camera with network interface to play with.
Getting standard cameras to work on the video card was no real problem. The network camera, on the other hand, is proving to be a bit of a nightmare.
I get the following entries in /var/log/messages:
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Debug Level = 0, Debug Log = ]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Got 1 monitors]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [monitor purpose=1]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [shm.size=6000448]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Initialised zone 0/All - 1 - 200x100 - Rgb:ff0000, AT:15, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Monitor RM1 has function 3]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Monitor RM1 LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Monitor RM1 IBC = 100, WUC = 25, pEC = 10, PEC = 10, FRI = 1000, RBP = 10]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Got 1 zones for monitor RM1]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Initialised zone 3/All - 1 - 200x100 - Rgb:ff0000, AT:25, MnAP:600, MxAP:15000, FB:3x3, MnFP:600, MxFP:15000, MnBS:400, MxBS:0, MnB:1, MxB:0]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Loaded monitor 3(RM1), 1 zones]
Nov 27 17:01:20 spook zmc-hCS-00508F[1453]: INF [Starting Capture]
Nov 27 17:01:20 spook zma-m3[1457]: INF [Debug Level = 0, Debug Log = ]
Nov 27 17:01:20 spook zma-m3[1457]: INF [Got 1 monitors]
Nov 27 17:01:20 spook zma-m3[1457]: INF [monitor purpose=2]
Nov 27 17:01:20 spook zma-m3[1457]: INF [shm.size=6000448]
Nov 27 17:01:20 spook zma-m3[1457]: INF [Initialised zone 0/All - 1 - 200x100 - Rgb:ff0000, AT:15, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
Nov 27 17:01:20 spook zma-m3[1457]: INF [Monitor RM1 has function 3]
Nov 27 17:01:20 spook zma-m3[1457]: INF [Monitor RM1 LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
Nov 27 17:01:20 spook zma-m3[1457]: INF [Monitor RM1 IBC = 100, WUC = 25, pEC = 10, PEC = 10, FRI = 1000, RBP = 10]
Nov 27 17:01:59 spook zmc-d2[1441]: INF [m1: 1000 - Capturing at 25.00 fps]
Nov 27 17:01:59 spook zma-m2[1445]: INF [m1: 1000 - Processing at 25.00 fps]
and the following in /var/log/syslog
Nov 27 17:45:39 spook zma-m3[1457]: WAR [Waiting for capture daemon]
Nov 27 17:45:40 spook zma-m3[1457]: WAR [Waiting for capture daemon]
Nov 27 17:45:41 spook zmc-hCS-00508F[1453]: ERR [Select timed out]
Nov 27 17:45:41 spook zma-m3[1457]: WAR [Waiting for capture daemon]
Nov 27 17:45:42 spook zma-m3[1457]: WAR [Waiting for capture daemon]
Nov 27 17:45:43 spook zmc-hCS-00508F[1453]: ERR [Select timed out]
Nov 27 17:45:43 spook zma-m3[1457]: WAR [Waiting for capture daemon]
Nov 27 17:45:44 spook zma-m3[1457]: WAR [Waiting for capture daemon]
Nov 27 17:45:45 spook zmc-hCS-00508F[1453]: ERR [Select timed out]
I've tried all the suggestions I've seen in the forums that might be relevant - all to no avail.
Does anyone have a clue what's going on her? - or is it back to debugging mode again??!!!
Regards,
Dave
Remote camera - Wot? - No picture!!
Re: Remote camera - Wot? - No picture!!
See the thread entitled " TRENDNet TV-IP200" for more information should you be interested!
Dave.
Dave.
