Page 1 of 1
Problem with monitor view
Posted: Tue Dec 26, 2006 9:07 pm
by herrmanna
I have installed zoneminder and I have config a monitor with a hauppauge bttv card
Source = video0
Cahnnel=1
when i click to Monitor name then open a windows with alternate text on imagebox i see not the preview from cam when i going to zones then i see the picture of cam.
have you an tip????
BR
Herrmann
Posted: Wed Dec 27, 2006 12:20 pm
by jameswilson
What os are you using?
Anythinfg in the logs?
Ok Monitor works now I have change the options no mpeg
Posted: Wed Dec 27, 2006 12:51 pm
by herrmanna
Hi
I use now cambozola and its works.
But I become no events i have setup a zone and when i going in forground of cam then i become no events.
It's psoible for setup the images for one event I need not every ms a image i need every 1 seconds 2 images.How can I condfigure that???
BR
herrmann
I have follow errors in the Browser
Posted: Wed Dec 27, 2006 5:48 pm
by herrmanna
1. Warning: Division by zero in /usr/local/httpd/htdocs/zm_html_view_montage.php on line 54 -
when i clicking onmontage
2. Warning: Division by zero in /usr/local/httpd/htdocs/zm_html_view_cycle.php on line 69
Warning: Division by zero in /usr/local/httpd/htdocs/zm_html_view_cycle.php on line 70
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 101
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 102
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 103
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 104
Warning: Cannot add header information - headers already sent by (output started at /usr/local/httpd/htdocs/zm_html_view_cycle.php:69) in /usr/local/httpd/htdocs/zm_funcs.php on line 105
When I clicking on Cycle
3.Fatal error: Call to undefined function: glob() in /usr/local/httpd/htdocs/zm_funcs.php on line 1764
when I clicking on Options System Tab
Can you help me????
Posted: Wed Dec 27, 2006 9:25 pm
by zoneminder
How many monitors do you have defined, and what are they set to do?
point 1 to point 2 are works now but point 3
Posted: Thu Dec 28, 2006 9:06 am
by herrmanna
Hello
Montage and cycle works now you have right I have not correct the monitors.
But the point 3 I can not find a solution.
I need the seetings for pan and tilt and this is finding on tab system but I become the point 3 message.
Can you interpret this???
BR
herrmann
Posted: Fri Dec 29, 2006 8:26 am
by Cell
If I may add my two cents worth, having had the same problem. The Montage view being devoid of anything, and the Zone Minders logs not reporting any errors.
The error in the Apache log:
"Division by zero in /usr/local/httpd/htdocs/zm_html_view_montage.php on line 54"
Was resolved when I placed my monitors into a group as specified in the Readme.pdf page 20 second last paragraph before "8.2 Defining Zones"
Hope this helps
Cell
Neglected to mention:
ZoneMinder 1.22.3
OS = Slackware 11
Kernel 2.6.19.1
PHP 5.2.0
