PurgeWhenFull Filter is missing
I seem to be missing the PurgeWhenFull filter. I think that my client deleted it because I believe I set it when I installed the system. How do I add it back.
Yes but...
My version is 1.21.4
When I open the event filters, there is no choice of PurgeWhenFull in the drop down arrow. Cordel, I can e-mail you the IP address of the site if this helps.
One more time
There is no ability for me to choose "PurgeWhenFull" to make those choices. Do you want the IP address to look at it yourself?
Ok, I think I got it
I see that I need to save the filter as set to get the ability to SAVE the name and choose the delete box. I was missing the SAVE step to insert the PurgeWhenFull name.
