How to detect and set the card to its best supported mode
Posted: Sun Jan 07, 2007 11:36 am
Hi thee,
I have a cctv card that said it supports 8-port real-tine capture; however, when i connect the cam with zoneminder, i use local mode (192.168.1.x/zm/) to view the page, the streaming is not smooth. I would like to know if there is any parameter I could config in module.conf to make sure the card is setup to its best supported mode?
Thanks .
Thanks .
