Grandtech III turns itself off
jerji
Post by jerji »
I am using zoneminder to monitor our church facilities after four breakins :cry:
It has been working REALLY well, but...
I have noticed lately that one of three grandtech cameras that were all working fine has suddenly started turning itself off :?
I have it changing from monitor to modect at night and then back to monitor during the day, all via a cron job, which seems to be working perfectly :)
When I go in to check the system the camera in question has turned off the 'enable' tick in the config. I turn it back on and it accepts the change (the console has the camera all back to orange - if it is in moitor mode - or green if it is in modect mode). Come back some time later and it is red again (mumble, mumble).
I know that no-one else is playing with it (for fear of broken fingers :wink: )
I have checked the forums but cannot find anything like this behaviour.
Any idea where I can start troubleshooting?
After another broken window last night I am keen to fix this ASAP.
Jerji
cordel
Post by cordel »
Is this system available through the internet and if so would you mind PMing me SSH and web access?
Flash_
Post by Flash_ »
Sounds like the bug with the last version where the enabled states are not saved when you switch run-modes.
I believe it was fixed in the most recent version (although I've not tried it) but it was reported by Phil at the time to be a bug rather than a config issue - the "Enabled" value simply wasn't saved to the sql.
cordel
Post by cordel »
This problem has been addressed in the current release 1.22.3 and I think it was addressed in 1.22.2 as well.
I can patch your version of 1.22.0 to fix this issue or it might be better for you to just upgrade to the current release. This is a known problem with the version you are running.
Regards,
Corey
