Page 1 of 1
getting the GS1200/NC1200 to work in zoneminder
Posted: Fri Jan 19, 2007 2:01 pm
by everythingcool
I just bought the GS1200 from gadspot , recently, but i cant seem to get them working with zoneminder, can anyone help , i currently have the following settings
remote host name 145.165.707.4
remote host port 80
remote host path /cgi-bin/getimage.cgi
pixel width 640
pixel hieght 480
Posted: Sat Jan 20, 2007 8:44 am
by Flash_
Use the path
/Jpeg/CamImg.jpg
The width and height are dependant on what you set it on the camera by Internet Explorer (ie, the activex resize function). You can't specify the size by url as you can with axis.
Colour would be 24-bit normal.
Posted: Sat Jan 20, 2007 12:01 pm
by moses
also have a look at:
http://www.zoneminder.com/forums/viewto ... ght=nc1200
I spend several hours in getting this cam working within Zoneminder.
I have the feeling, that the camera has some networking problems - which
are not related to Zoneminder.
Also: everytime you change the settings: turn the cam off/on and restart ZM.
I could only get the cam working with Remote-Host-Path: /cgi-bin/getimage.cgi?motion=1
regards
Bernhard
