edimax IC-1500Wg
edimax IC-1500Wg
Has anyone tried to get the EDIMAX IC-1500Wg wireless network cam to work will zone minder?
I am even not able to view camera output in my browser (linux + firefox).
If you searched the forum you'll find someone claimed to get an earlier model to work but required some special script. It would apprear that it might not really be compatable without the script. Hence it's also not on the compatable hardware list either.
http://www.zoneminder.com/forums/viewto ... ght=edimax
I can't say if it would work with IC-1500Wg.
After googling a bit, I found that this camera runs under different brand names, sold in different parts of the world. The camera is available with or without the wireless module. The Wireless version costs about 20% more than the wired-only model. See some examples, there may be more:
Edimax IC-1500 (Central + Eastern Europe)
Hawking HNC230G (US) (this one seems that internally matches with Edimax IC-1000 - not sure)
AmberTek GC-J15W (Asia)
IP Camera Roline, RWIC-54, W-LAN54 (21.18.1675) (Russia)
Logilink WC0001 (Germany, Western Europe)
Some technical data, this may also help:
Found something for the Hawking model, made by Tim Haynes:
http://spodzone.org.uk/packages/hawking-HNC230G.txt
Any idea how to implement it into ZM?
#!/usr/bin/env ruby
# Script to extract images from the Hawking HNC230G
# Copyright (C) Tim Haynes
# HNC230G{at}stirfried.vegetable.org.uk http://pig.sty.nu/
# Redistributable under the terms of the GNU Public License: see
# <http://www.gnu.org/copyleft/gpl.html>
# Requires ruby, imagemagick
nopics=ARGV[1] || "1"
nopics=nopics.to_i
require 'socket'
require 'RMagick'
xsize,ysize=640,480
puts "Connecting"
s=TCPSocket.new('buffalo', 4321)
nopics.times { |n|
puts "Requesting data"
s.puts("0110")
len=s.read(2).reverse.unpack("v")[0]
2.times {s.getc }
puts "Len: #{len}"
jpeg=s.read(len)
puts "Getting image"
img=Magick::Image.from_blob(jpeg)[0];
puts "Saving image"
img.write("foo-#{n}.jpg")
Some other URL I found, that may be interesting:
http://www.darkwet.net/darkboard2/topic ... IC_ID=4862
The camera uses an ActiveX control to display image in browser.
I downloaded it from the camera (the url is http://xxx.xxx.x.xx/IPCamPluginMJPEG.cab), unpacked it with WinRAR, registered the IPCamPluginMJPEG.ocx with regsvr32.
Then, I created a new webpage with a Html editor. Added this ActiveX control to the page, like this:
And guess what? It works! No username or password required.
Please note the "Code" parameter. I found this by right-click-ing near the picture (camera_right frame) in the camera's viewer page and selecting view source.
Without this parameter the html won't work. Wonder if the code is the same for the other Edimax owners.
Is it possible that this code is actually the one that corresponds to '0110' at the older Edimax 1000 or the Hawking model?
Is there a way to know what this ActiveX actually does (beside applying the viewer's current time and date on the picture
)? To make a new script with the same tasks.
Any help would be greatly appreciated.
<html>
<head>
<title>EdimaxTest</title>
</head>
<body>
<p>
<object classid="clsid:B015B944-7316-49AE-AC84-ACCA9379EA32" id="IC1500PlugIn1" width="611" height="585">
<PARAM name="IP" value="xxx.xxx.x.xx">
<PARAM name="Port" value="4321">
<PARAM name="Code" value="A99EDF974454ADE3674A">
</object>
</p>
</body>
</html>
Hello!
You can get images from your camera with my PHP script and a web server in the following form:
http://webserver/Edimax_IC1500.php
I think, ZM likes this.
Sorry for my english.
$login = "admin";
$pass = "xxxxxxx";
$ip = "aa.bb.cc.dd";
$port = "4321";
// 120 byte
// 3x 0x00,
// 1x 0x01,
// user name
// 1x 0x00,
// password,
// Nx 0x00,
$logincmd = pack(
"x3H*a*xa*x" .
(120 - 3 - 1 - strlen($login) - 1 - strlen($pass)),
"01", $login, $pass);
// 120 byte
// 3x 0x00,
// 1x 0x0e,
// Nx 0x00,
$framecmd = pack("x3H2x116", "0e");
$login_ok_reply = "0c";
function error($msg)
global $sock;
if ($sock) {
fclose($sock);
die($msg);
function request($sock, $cmd, $len)
$ret = fwrite($sock, $cmd, $len);
if (!$ret) {
error("request()/fwrite()==FALSE");
if ($ret != $len) {
error("request()/fwrite(): written: {$len}/{$ret}");
fflush($sock);
function dump($data, $file)
$f = fopen($file, "wb");
if (!$f) {
error("dump()/fopen()");
$ret = fwrite($f, $data);
if (!$ret) {
error("dump()/fwrite()");
fclose($f);
$sock = fsockopen("tcp://$ip", $port);
if (!$sock) {
error("fsockopen(tcp://$ip:$port)");
// 350ms
stream_set_timeout($sock, 0, 350000);
request($sock, $logincmd, 120);
//echo("login request sent\n");
$ret = stream_get_contents($sock, 120);
//echo("login reply received\n");
if (strlen($ret) != 120) {
error("Error in reply for login. size:120/" . strlen($ret));
//dump($ret, "0.dump");
$reply = unpack("H*", $ret[3]);
if ($reply[1] != $login_ok_reply) {
error("Login incorrect!");
//echo("OK\n");
request($sock, $framecmd, 120);
//echo("get frame request sent\n");
// 6 fix byte
$ret = fread($sock, 6);
if (!$ret) {
error("Frame signature fread()==FALSE");
//dump($ret, "1.dump");
$sig = unpack("H*", $ret);
if ($sig[1] != "000700060000") {
error("Frame signature incorrect");
//echo("frame signature ok\n");
// 2 byte: jpeg size.
$ret = fread($sock, 2);
if (!$ret) {
error("Frame size fread()==FALSE");
//dump($ret, "2.dump");
$unpacked = unpack("H*", $ret);
sscanf($unpacked[1], "%04x", $frame_size);
//echo("frame_size = $frame_size\n");
// 20 byte ???.
$ret = fread($sock, 20);
if (!$ret) {
error("Skip before frame fread()==FALSE");
// JPEG: $frame_size byte.
$ret = stream_get_contents($sock, $frame_size);
if (!$ret) {
error("Frame data stream_get_contents()==FALSE");
if (strlen($ret) != $frame_size) {
error("Frame data stream_get_contents() size: " .
"{$frame_size}/" . strlen($ret));
header("Content-Type: image/jpeg");
header("Content-Length: $frame_size");
header("Content-Disposition: inline; filename=current.jpg");
echo($ret);
fclose($sock);
