Static URL to unsupported cams
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
wesalmon
Post by wesalmon »
I have a wireless webcam that I bought that is unsupported. It would be great if there was a way just add a static url to cams that are not currently supported. That would give a single console for all cameras. Just the ability to launch the link to the camera would be a step in the right direction.
cordel
Post by cordel »
Would you care to elaborate on that?
I don't understand what you mean add a static link where?
How would this be a new feature or how would it work?
All your camera configuration is covered in 8.1. Defining Monitors in the manual where you define your path (link) to the camera.
What camera do you have?
Why do you think it not supported?
wesalmon
Post by wesalmon »
I have a Hawking HNC320W. I have seen old posts that it can be made to work, but it requires breaking my existing cams. It requires some java client to access so it is not likely to be compatible soon. I have been using ZM for a while with great success and am familiar with configuration details for usb/local and IP cams.
What I am looking for is for the source to be the actual source. Meaning, if I put a camera at 192.168.1.10, when I click on the camera name, the static link directs me to that IP. A simple check box in the config for "static" would tell the interface to ignore all other settings and just launch the URL entered in the configuration. Of course there would be no data collection, but it would allow me to at least use the camera from a single interface. I am sure there are many, many cameras people have bought that do not work that are just collecting dust. (the newer Dlink ones?)
Thank you.
cordel
Post by cordel »
Okay that makes since, Thank you and sounds like a very feisible feature. I'll look into it ;)
wesalmon
Post by wesalmon »
My mistake... The cam that isn't supported is the HNC230G.
cordel
Post by cordel »
Yeah I noticed that, You know I would search the forum don't ya ;)
one link stood out and actualy needed to be revisited and way:
http://www.zoneminder.com/forums/viewto ... ht=hnc320w
wesalmon
Post by wesalmon »
Great! I will be happy to beta test. Should I expect an update later today? javascript:emoticon(':lol:')
Laughing
Thank you.
cordel
Post by cordel »
Yeah I wish I could be that fast, but duty calls and I must go to work :( I also just got an assignment 1300 miles away from home so hopefully I'll be back in a few weeks.
:x :x :x :x but I have one of those feelings it might be a six week trip :cry: :cry: :cry:
And from something I seen on another post, I'm going to embellish on this feature a little :roll:
So not only to have the link available but also an option to be able to retrieve the feed from the camera directly in the zm monitor window so that the zm server does not have to provide the feed for remote cameras (like the axis which can support multiple simultaneous feeds).
;) Since they are very simular in nature. ;)
wesalmon
Updates?
Post by wesalmon »
I can't believe it has been a year already. I was going to update my ZM and thought I would check on this. Is there any work being done on this, or should I just ebay the ones that don't work?
Thanks again!
