Page 1 of 1
Static URL to unsupported cams
Posted: Thu Feb 08, 2007 6:14 pm
by wesalmon
I have a wireless webcam that I bought that is unsupported. It would be great if there was a way just add a static url to cams that are not currently supported. That would give a single console for all cameras. Just the ability to launch the link to the camera would be a step in the right direction.
Posted: Thu Feb 08, 2007 6:21 pm
by cordel
Would you care to elaborate on that?
I don't understand what you mean add a static link where?
How would this be a new feature or how would it work?
All your camera configuration is covered in 8.1. Defining Monitors in the manual where you define your path (link) to the camera.
What camera do you have?
Why do you think it not supported?
Posted: Thu Feb 08, 2007 6:40 pm
by wesalmon
I have a Hawking HNC320W. I have seen old posts that it can be made to work, but it requires breaking my existing cams. It requires some java client to access so it is not likely to be compatible soon. I have been using ZM for a while with great success and am familiar with configuration details for usb/local and IP cams.
What I am looking for is for the source to be the actual source. Meaning, if I put a camera at 192.168.1.10, when I click on the camera name, the static link directs me to that IP. A simple check box in the config for "static" would tell the interface to ignore all other settings and just launch the URL entered in the configuration. Of course there would be no data collection, but it would allow me to at least use the camera from a single interface. I am sure there are many, many cameras people have bought that do not work that are just collecting dust. (the newer Dlink ones?)
Thank you.
Posted: Thu Feb 08, 2007 6:46 pm
by cordel
Okay that makes since, Thank you and sounds like a very feisible feature. I'll look into it
Posted: Thu Feb 08, 2007 6:47 pm
by wesalmon
My mistake... The cam that isn't supported is the HNC230G.
Posted: Thu Feb 08, 2007 6:53 pm
by cordel
Yeah I noticed that, You know I would search the forum don't ya
one link stood out and actualy needed to be revisited and way:
http://www.zoneminder.com/forums/viewto ... ht=hnc320w
Posted: Thu Feb 08, 2007 6:54 pm
by wesalmon
Great! I will be happy to beta test. Should I expect an update later today? javascript:emoticon(':lol:')
Laughing
Thank you.
Posted: Thu Feb 08, 2007 7:02 pm
by cordel
Updates?
Posted: Tue Apr 29, 2008 9:34 pm
by wesalmon
I can't believe it has been a year already. I was going to update my ZM and thought I would check on this. Is there any work being done on this, or should I just ebay the ones that don't work?
Thanks again!
