Page 1 of 1
cameras not usable with authentication on
Posted: Fri Feb 09, 2007 4:48 am
by bbarnett
Just installed and setup the new deb package! Thanks for that, Peter!
Anyhow, everything works fine, unless I turn on authentication. Once I do, none of my cameras work. I tried deleting and re-adding my cameras, and it's a no go.
I don't see where to place authentication in any of the monitor configuration windows. I'm using simple V4L cameras, /dev/video0 and so on.
Again, everything works perfectly until I turn authentication on. Any suggestions?
Posted: Fri Feb 09, 2007 5:20 am
by cordel
Have you restarted the zm services since making the change????
If so then I suggest you start here http://www.zoneminder.com/forums/viewtopic.php?t=6427
Posted: Fri Feb 09, 2007 4:17 pm
by bbarnett
cordel wrote:Have you restarted the zm services since making the change????
Yes, I restarted many times. As for the FAQ and Manual, a search of "authentication" provided no joy before I posted. Searching google for the same on zoneminder.com's forum, didn't lead to anything either. :/
Anyhow, from my initial post, 1.22.3 and Debian.
Logs that I can see as relevant:
09/02/07 08:40:56.213893 zmdc[22273].WAR [Can't find process with command of 'zmc -d /dev/video0']
09/02/07 08:40:56.503400 zmdc[22273].INF ['zmc -d /dev/video0' starting at 07/02/09 08:40:56, pid = 9288]
09/02/07 08:40:56.624611 zmdc[22273].INF ['zmc -d /dev/video0' already running at 07/02/09 08:40:56, pid = 9288]
09/02/07 08:40:56.801586 zmdc[22273].WAR [Can't find process with command of 'zma -m 2']
Doesn't happen with auth off. Does with internal ZM auth on.
Any ideas? :(
Posted: Sat Feb 24, 2007 11:42 am
by chrisfu
I can confirm that this exact same problem is happening for me as well. Again, using Peters latest .deb package. Also seeing a very similar log behaviour.
I can confirm however that the cameras are picking up events and logging them, it seems to be exclusively a problem with web-streaming the live feed and logged events.
Posted: Sat Feb 24, 2007 3:10 pm
by bbarnett
For some reason, the default is for ZM_AUTH_RELAY to be on, when it should be set to "none". This isn't covered anywhere I can see, so I'm not sure why it is even set to on.
Anyhow, turn that off, and you'll be fine. At least, I believe that this is the option I changed. If not, get back to me, and I can double check...
