Hi all!
What frame rate (fps) should be expected from an 8-chip bt878 16-input card? Each chip is capable of 30fps, the card total is 240fps. If I setup a monitor using /dev/video0 - channel 0 I am able to get 30fps, but the instant I setup a monitor using /dev/video0 - channel 1, the rate on both monitors drops to 5fps. I expected to get something lower than 15fps (30fps/2channels) from each channel from the same device... but 5 seems way too low. 10fps would be great for me... Is there any way to get a higher frame rate?
Here's something else: If I delete the monitor on channel 1, I keep on getting 5fps on channel 0 until I restart ZM.
The card is bluecherry's PV183-16.
Regards,
Gonzalo
Expected frame rate
I found some info in the forums regarding my question:
http://www.zoneminder.com/forums/viewtopic.php?t=6987
Someone says he gets 5fps max using 2 cams per chip, exaclty whay I get, and someone else says he gets 10fps... any idea how to get to 10?
