Page 1 of 1
Spectra 8 and FC6
Posted: Sat Feb 17, 2007 10:01 am
by ianafh
Hello All,
I am just building a new system with FC6 and a spectra 8 card. The card has been in use in my old FC4 based system without problems for some time now. However I have been unable to get the card to work with FC6.
From the logs it looks like the card is automagically detected by the kernel, but not without error. See below for extract of /var/log/messages.
In FC6 there is no modules.conf to add the usual 'card=42,42....' line to so I tried adding the line to modprobe.conf without sucess.
How do I configure FC6 to use this card?
Any suggestions gratefully received.
Ian.
Feb 17 08:59:28 localhost kernel: bttv: driver version 0.9.16 loaded
Feb 17 08:59:28 localhost kernel: bttv: using 8 buffers with 2080k (520 pages) each for capture
Feb 17 08:59:28 localhost kernel: bt878: Unknown symbol bttv_read_gpio
Feb 17 08:59:28 localhost kernel: bt878: Unknown symbol bttv_write_gpio
Feb 17 08:59:28 localhost kernel: bt878: Unknown symbol bttv_gpio_enable
Feb 17 08:59:28 localhost kernel: eth0: forcedeth.c: subsystem: 01043:8234 bound to 0000:00:07.0
Feb 17 08:59:28 localhost kernel: bttv: Bt8xx card found (0).
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 19
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:08.0[A] -> Link [LNKB] -> GSI 19 (level, low) -> IRQ 20
Feb 17 08:59:28 localhost kernel: bttv0: Bt878 (rev 17) at 0000:02:08.0, irq: 20, latency: 64, mmio: 0xdcfff000
Feb 17 08:59:28 localhost kernel: bttv0: detected: ituner spectra8 [card=42], PCI subsystem ID is aa0c:146c
Feb 17 08:59:28 localhost kernel: bttv0: using: ProVideo PV951 [card=42,autodetected]
Feb 17 08:59:28 localhost kernel: bttv0: using tuner=1
Feb 17 08:59:28 localhost kernel: bttv0: i2c: checking for TDA9875 @ 0xb0... not found
Feb 17 08:59:28 localhost kernel: bttv0: i2c: checking for TDA7432 @ 0x8a... not found
Feb 17 08:59:28 localhost kernel: bttv0: i2c: checking for TDA9887 @ 0x86... not found
Feb 17 08:59:28 localhost kernel: bttv0: registered device video0
Feb 17 08:59:28 localhost kernel: bttv0: registered device vbi0
Feb 17 08:59:28 localhost kernel: bttv0: PLL: 28636363 => 35468950 .. ok
Feb 17 08:59:28 localhost kernel: bttv: Bt8xx card found (1).
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 18
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:09.0[A] -> Link [LNKC] -> GSI 18 (level, low) -> IRQ 21
Feb 17 08:59:28 localhost kernel: bttv1: Bt878 (rev 17) at 0000:02:09.0, irq: 21, latency: 64, mmio: 0xdcffd000
Feb 17 08:59:28 localhost kernel: bttv1: subsystem: aa0d:146d (UNKNOWN)
Feb 17 08:59:28 localhost kernel: bttv1: using:  *** UNKNOWN/GENERIC ***  [card=0,autodetected]
Feb 17 08:59:28 localhost kernel: bttv1: using tuner=-1
Feb 17 08:59:28 localhost kernel: bttv1: i2c: checking for MSP34xx @ 0x80... not found
Feb 17 08:59:28 localhost kernel: bttv1: i2c: checking for TDA9875 @ 0xb0... not found
Feb 17 08:59:28 localhost kernel: bttv1: i2c: checking for TDA7432 @ 0x8a... not found
Feb 17 08:59:28 localhost kernel: bttv1: i2c: checking for TDA9887 @ 0x86... not found
Feb 17 08:59:28 localhost kernel: bttv1: registered device video1
Feb 17 08:59:28 localhost kernel: bttv1: registered device vbi1
Feb 17 08:59:28 localhost kernel: bttv: Bt8xx card found (2).
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 17
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:0a.0[A] -> Link [LNKD] -> GSI 17 (level, low) -> IRQ 22
Feb 17 08:59:28 localhost kernel: bttv2: Bt878 (rev 17) at 0000:02:0a.0, irq: 22, latency: 64, mmio: 0xdcffb000
Feb 17 08:59:28 localhost kernel: bttv2: subsystem: aa0e:146e (UNKNOWN)
Feb 17 08:59:28 localhost kernel: bttv2: using:  *** UNKNOWN/GENERIC ***  [card=0,autodetected]
Feb 17 08:59:28 localhost kernel: bttv2: using tuner=-1
Feb 17 08:59:28 localhost kernel: bttv2: i2c: checking for MSP34xx @ 0x80... not found
Feb 17 08:59:28 localhost kernel: bttv2: i2c: checking for TDA9875 @ 0xb0... not found
Feb 17 08:59:28 localhost kernel: bttv2: i2c: checking for TDA7432 @ 0x8a... not found
Feb 17 08:59:28 localhost kernel: bttv2: i2c: checking for TDA9887 @ 0x86... not found
Feb 17 08:59:28 localhost kernel: bttv2: registered device video2
Feb 17 08:59:28 localhost kernel: bttv2: registered device vbi2
Feb 17 08:59:28 localhost kernel: bttv: Bt8xx card found (3).
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 16
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:0b.0[A] -> Link [LNKA] -> GSI 16 (level, low) -> IRQ 23
Feb 17 08:59:28 localhost kernel: bttv3: Bt878 (rev 17) at 0000:02:0b.0, irq: 23, latency: 64, mmio: 0xdcff9000
Feb 17 08:59:28 localhost kernel: bttv3: subsystem: aa0f:146f (UNKNOWN)
Feb 17 08:59:28 localhost kernel: bttv3: using:  *** UNKNOWN/GENERIC ***  [card=0,autodetected]
Feb 17 08:59:28 localhost kernel: bttv3: using tuner=-1
Feb 17 08:59:28 localhost kernel: bttv3: i2c: checking for MSP34xx @ 0x80... not found
Feb 17 08:59:28 localhost kernel: bttv3: i2c: checking for TDA9875 @ 0xb0... not found
Feb 17 08:59:28 localhost kernel: bttv3: i2c: checking for TDA7432 @ 0x8a... not found
Feb 17 08:59:28 localhost kernel: bttv3: i2c: checking for TDA9887 @ 0x86... not found
Feb 17 08:59:28 localhost kernel: bttv3: registered device video3
Feb 17 08:59:28 localhost kernel: bttv3: registered device vbi3
Feb 17 08:59:28 localhost kernel: EDAC MC0: Giving out device to k8_edac Athlon64/Opteron: DEV 0000:00:18.2
Feb 17 08:59:28 localhost kernel: bt878: AUDIO driver version 0.0.0 loaded
Feb 17 08:59:28 localhost kernel: bt878: Bt878 AUDIO function found (0).
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:08.1[A] -> Link [LNKB] -> GSI 19 (level, low) -> IRQ 20
Feb 17 08:59:28 localhost kernel: bt878_probe: card id=[0x146caa0c], Unknown card.
Feb 17 08:59:28 localhost kernel: Exiting..
Feb 17 08:59:28 localhost kernel: ACPI: PCI interrupt for device 0000:02:08.1 disabled
Feb 17 08:59:28 localhost kernel: bt878: probe of 0000:02:08.1 failed with error -22
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:09.1[A] -> Link [LNKC] -> GSI 18 (level, low) -> IRQ 21
Feb 17 08:59:28 localhost kernel: bt878_probe: card id=[0x146daa0d], Unknown card.
Feb 17 08:59:28 localhost kernel: ACPI: PCI interrupt for device 0000:02:09.1 disabled
Feb 17 08:59:28 localhost kernel: bt878: probe of 0000:02:09.1 failed with error -22
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:0a.1[A] -> Link [LNKD] -> GSI 17 (level, low) -> IRQ 22
Feb 17 08:59:28 localhost kernel: bt878_probe: card id=[0x146eaa0e], Unknown card.
Feb 17 08:59:28 localhost kernel: ACPI: PCI interrupt for device 0000:02:0a.1 disabled
Feb 17 08:59:28 localhost kernel: bt878: probe of 0000:02:0a.1 failed with error -22
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:02:0b.1[A] -> Link [LNKA] -> GSI 16 (level, low) -> IRQ 23
Feb 17 08:59:28 localhost kernel: bt878_probe: card id=[0x146faa0f], Unknown card.
Feb 17 08:59:28 localhost kernel: ACPI: PCI interrupt for device 0000:02:0b.1 disabled
Feb 17 08:59:28 localhost kernel: bt878: probe of 0000:02:0b.1 failed with error -22
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 22
Feb 17 08:59:28 localhost kernel: ACPI: PCI Interrupt 0000:00:05.0[B] -> Link [LAZA] -> GSI 22 (level, low) -> IRQ 17
Feb 17 08:59:28 localhost kernel: Floppy drive(s): fd0 is 1.44M
Feb 17 08:59:28 localhost kernel: FDC 0 is a post-1991 82077
Feb 17 08:59:28 localhost kernel: lp0: using parport0 (interrupt-driven).
Feb 17 08:59:28 localhost kernel: lp0: console ready
Feb 17 08:59:28 localhost kernel: sonypi: Sony Programmable I/O Controller Driver v1.26.
Feb 17 08:59:28 localhost kernel: NET: Registered protocol family 10
Feb 17 08:59:28 localhost kernel: lo: Disabled Privacy Extensions
Feb 17 08:59:28 localhost kernel: Mobile IPv6
Feb 17 08:59:28 localhost kernel: ACPI: Power Button (FF) [PWRF]
Feb 17 08:59:28 localhost kernel: ACPI: Power Button (CM) [PWRB]
Feb 17 08:59:28 localhost kernel: md: Autodetecting RAID arrays.
Feb 17 08:59:28 localhost kernel: md: autorun ...
Feb 17 08:59:28 localhost kernel: md: ... autorun DONE.
[/quote]
Sepctra 8 and FC6
Posted: Sun Feb 18, 2007 10:54 am
by ianafh
Hi All
I have tried adding this to /etc/modprobe.conf
options bttv card=42,42,42,42 pll=1 radio=0 tuner=4 sloppy=1 chroma_agc=1 mmap=1 vbibufs=4 v4l2=1 gbuffers=16
dmesg shows the following errors:-
bttv: Unknown parameter `sloppy'
Anyone have any idea on where I should look or ask for help in resolving this problem?
Thanks in advance
Ian.
Spectra 8 and FC6
Posted: Sun Feb 18, 2007 11:35 am
by ianafh
Hi All
Some success. I removed some of the options from modprobe.conf and now things seem to be running.
options bttv card=42,42,42,42 pll=1 tuner=4
Is there a guide to these options somewhere?
Ian.
Posted: Sun Feb 18, 2007 10:01 pm
by cordel
Usualy found in /usr/share/doc/kernel/v4l and might require you to install kernel-docs package.
Posted: Fri Aug 24, 2007 12:44 pm
by biologisch
Hi!
Here I have the same problem with fedora 7.
The next is, that only the first channel (/dev/video0) shows the picture colored. Others are b/w. :roll:
Fedora 7 and Spectra8 card b/w problem is solved!
Posted: Sat Jan 05, 2008 4:33 pm
by biologisch
So, here are the enty in my /etc/modprobe.conf
options bttv card=42,42,42,42 radio=0 tuner=4
Now all cams are colored!
:lol:
